Question about XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI Express Graphics Card
My monitor has no input signal when i plug it on my xfx 8800gt alphadog. i've been using it for almost 5 mos, then all of a sudden, when i start my PC my mmonitor is ok but after 3-5 minutes it says no input signal. ive tried my monitor on my on board and it works fine. pls give me solutions for this ASAP. TY
  • Christopher Caluag Feb 28, 2009
    ive tried that already but still the problem exist. i also put my card on my friend PC and same problem after few minutes after the boot his monitor says no input signal. we have the same monitor HP w2207h. pls give me other solutions. thanks
  • Robert Jennings
    Robert Jennings May 11, 2010
    Have you used the nVidia control panel to check the temperature of the card? Have you verified that your cooling fan on the card is still running? It sounds like the card is heating up and shutting down. I would be surprised if it were clogged with dust after only 5 months.
  • 21 Answers
Your card is probably overheating. the alphadog editon has an extremly small cooling for the gpu. try cleaning it with a caned air spray and check the NVIDIA control panel to see the temp. of the GPU if the problem is solved try running a game benchmark to see if that works.
Posted on Feb 28, 2009
Loud buzzing when turn on, no input signal
put a song onto play using either tape, vinyl, cd or mp3.
once playing follow the wires from the speaker that doesn't work bending it until you hear it crack or become clear if it does either of those it is the wire between the head unit and the output.
if not you can try attaching the speakers to a different head unit if it doenst work it could be the driver (the cone doesn't have to go to blow a speaker)
Jan 02, 2014 | Mackie MR5-MK2 5" Powered 2 Way Reference...
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a HP 945GCT-HM Motherboard with 1 gb ram 450w psu pentium d cpu i have brought an XFX readon hd 5450 but it not working my monitor say vga input no signal
once you insert the XFX readon hd5450 card into PCI E slot on the motherboard go into the bios by tapping DELETE key until you see bios options and then go to advanced Tab and check if primary video adapter is selected to on-board and if yes change the same to PCI-E save the settings by selecting exit tab and then select exit saving changes and save and restart. I am sure it should then detect the graphic card and you can then plug in the monitor to the VGA slot on the Graphic card.
do reply if you need any more help Good luck.
Feb 06, 2012 | Computers & Internet
Compaq D315 showing no input signal
Check if the cable between PC and the monitor is tight and re-plug it.
Try using a different monitor - to check if monitor isn't broken. If another monitor works - it's a problem with monitor. It could be just a wrong chosen input - if it's true specify please your monitor type.
Try using the monitor on a different PC - if it works then you've a problem with your Compaq D315. Probably a problem with graphics.
Dec 31, 2011 | Compaq D315 Business PC PC Desktop
8800gt wont boot my 8800gtx will so it not power related please help
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
As your 8800GTX boots fine and your 8800GT does not boot one would say that your 8800GT is faulty.
How faulty one does not know, does the fan spin? If so then there is some life left in it.
A technician might replace the capacitors for a fee, this may get it working again.
There is not much else on can do but give it to a computer technician to try and repair it.
Regards
damnor01
Feb 11, 2011 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
I`ve just bought a Asus EAH5670 but its not working ,problem is: when I connect the 5670 gpu in my Mobo screen stays black but when I reinstall my XFX 8800gt alpha dog it works without any problems :S. I...
Have you made sure that you have correctly installed the 5670's VGA drivers (The ones on the CD that came with the card). In my opinion the XFX 8800GT is way better than the 5670 though, if this solves your ploblem and you don't want the 8800GT anymore send me a line at JP.Damstra@yahoo.com.
Nov 01, 2010 | ASUS A8N-VM CSM (00610839133826)...
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Screen all hazzy letters hard to read
Pull out the graphics card & RAM chips. Give their contact points a good cleaning and replace hem. Also check to see that all cables are snug tight. Finally remove the Monitor cord fro its slot at the back of the CPU and remove all dust and check if any pins are loose. See that the monitor plug is firmly placed..................sodeep
Apr 20, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI Express Graphics Card Logo
771 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
