Question about E-Machines eMachines Desktop PC
My e-machine desk top does not power up.
I believe that the problem is with the switch. is there an easy way to fix this problem?
thanks
  • Garrett Murray
    Garrett Murray May 11, 2010
    Why do you believe its with the switch and not the power supply?
    Thanks,
    Armymason
    Sergeant:
  • 268 Answers
There is a way to bypass the switch and start the computer, just to verify that the switch is the actual problem....the only thing is it requires you to open up the computer case. If you are not comfortable doing this, I would take it to a computer shop. I don't want to see you damage your computer!
Here are the directions:
  1. Open up the computer case
  2. Find the wire that is connected to the front switch
  3. Follow the wire to the motherboard and disconnect it from the 2 pins it is connected to
  4. Take a screw driver and touch both pins at the same time (Picture Below). This will create a connection, as if you pushed in the switch and should start the computer.
Now if the computer doesn't start , then you know the problem is not the switch and will have to further troubleshoot it. If it does start, try going to e-bay and searching for a replacement switch
Posted on Feb 24, 2009
Down load my samsung model sch-s738c to my desk top? and how to load my desk top to my samsung?
Samsung Smart Switch makes it easy to transfer contacts, photos, messages and more from your old phone to your new Galaxy.
Mar 12, 2016 | Samsung SCH Cell Phones
Samsung main power supply desk top monitorS20A350BS desk top
you must measure the output from your power supply see the diagram attached in the box. If some Voltage like +5vdc is missing you must replace the power supply. If the Monitor NOT turn ON try to test in another computer more easy. or go to the repair shop.Use the bottoms from the monitor and execute from the MENU make test.
God bless you
Jul 27, 2013 | Samsung Computers & Internet
The top of my desk is not smooth and it makes writing difficult. What can I do?
You can either buy a plastic/glass cover to fit the top of your desk and cover the surface, or you can fix it yourself with a little sanding and varnish. Here's a site that can take you through the necessary steps.
http://www.ehow.com/how_7862611_can-seal-top-writing-desk.html
Aug 15, 2012 | Furniture
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
I keep getting no signal when i turn on my emachine desk top
Its probably the power supply..they tend to go quick on emachines.!Replace the Power supply.
Jun 11, 2010 | E-Machines eMachines Desktop PC
Old hp pavilion (8674 F) desk top. server will
There is no fuse inside.If this is idle for a few years , might be there is some dust in switch so you will have to clean it once and also try with exchanging the power cords.
Thanks
Jan 05, 2010 | Compaq Pavilion ZT3280US Notebook
Desk top will not start
OPEN RAM SLOT AND CLEAN IT THEN PUT
Mar 20, 2009 | Gateway (4000811) Motherboard
Lid Switch Trigger Broken: How To Fix this?
There is no fix for the lever. Go to www.repairclinic.com and order you a new one. They are cheap and relatively easy to replace.
Mar 14, 2009 | Kenmore 22422 Top Load Washer
E-Machines eMachines Desktop PC Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
