Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Chainsaw won't start. Can't pull starting cord out
I’ve had a Homelite 45cc 18” chainsaw for about 2 years. In those two years it’s done everything I’ve asked of it including starting very easily every time. I’ve been extremely happy with it. I cut some wood on Saturday without a single problem and then on Monday when I tried to start it, I couldn’t pull the rope out more than an 1” – 1 ½”. I took the starter cover off and checked to make sure the rope hadn’t come off. I also took out the spark plug which was dry. When the plug is out I am able to pull the rope out all the way and I can see the piston moving up and down. However, as soon as I put the plug back in it goes right back to me not being able to pull the rope out again. I know nothing about engines and I’m hoping that someone has experienced this sort of thing before me and can tell me what what’s wrong.
  • 1 more comment
  • jeb3d Feb 25, 2009
    I'm able to blow through the exhaust box and there appears to be only minimal (if any) carbon buildup. The exhaust port looks brand new, no carbon buildup whatsoever. The cord can be pulled and the piston is fully clearing the exhaust port. I appreciate you taking time to try and help me with this. Thank you!
  • jeb3d Feb 26, 2009
    I took off the bar and clutch sprocket and the "innards" looked fine. Still unable to pull the cord with it off. I do very much appreciate you trying to help. I think it might be time to start thinking about a new chainsaw because I'm beginning to think that repairing this one might be more expensive than buying a new one.
  • lfoster01 May 11, 2010
    Remove your exhaust box, inspect it for carbon buildup and try to blow through it + check if you can pull the cord the whole way out with it off. Look through the exhaust port on the engine and make sure the piston is fully clearing it. Let me know.
  • 3 Answers
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Posted on May 09, 2009
    Problem Solver:
  • 7 Answers
A common problem with these saws was the plastic housing around the chain brake melting againt it and seizing the saw however this doesnt explain being able to pull it with the plug or exhaust removed. It might be worth a try pulling the bar and clutch sprocket off the side and see if you can see any damage and if you are able to pull it. If not it sounds like something in the starter housing is catching under load ie: with full compression in the engine. Let me know.
Posted on Feb 26, 2009
  • lfoster01 Mar 02, 2009
    That may be a rational idea as i have noticed there are countless complaints about the homelite and poulin range. May i suggest spending the extra dollars on a husqvarna or even a stihl as i work on these daily and with proper maintainance they are both brilliant saws. The initial expendature may be steep but they are ultra reliable, take A LOT of punishment before they give up, are usually cheap to fix, and retain an excellent resale value. Good luck, and happy cutting!
?Ÿ?µ???µ?³???µ?² ???¾???¿????° ?² ???°?¹?¾?½?µ ???¾???¼?¾?·?° ???µ?¿?¸ - ?¿?»?°????¸?? ?½?°?³???µ?»?? ?·?°???µ?¼ ?¾??????» ?¸ ?´?µ???¶?¸?? ???¾?»?µ?½?²?°?» ?¼?¾???¾???°.????¶?½?¾ ???°?·?¾?±???°???Œ ?¸ ?¾???¸????¸???Œ.
Posted on Mar 02, 2009
2 Suggested Answers
  • 11 Answers
SOURCE: Chainsaw won't start. Can't pull starting cord out
Thats a little strange.
Only thing that comes to mind is someone else had access to it and swapped out a plug that is too long for your short plug, Check plug type in owners manual.
maybe on sunday their 4 wheeler wouldn't start and this was quick fix.
Take off the chain cover or starter and see if it turns back and forth almost one full turn with a sudden stop at both ends of rotation. (Hitting plug)
if this is ok get back to me.
Bill
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
I need a manual for a Homelite chainsaw Where is
Hi calwolfe...
Go to the following website and download your manual, if it is among the list.
You did not get me a model so I did not have much to work with to find your user manual for your chainsaw.
Please take time to rate me
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Sep 10, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Have an xl 240, won't start. put fuel in carb and it runs, doesnt seem to get fuel from tank. How to fix this?
Check fuel line for obstruction first then you need to disassemble your carb a give a full cleaning maybe even rebuild it. Check out this link and watch the chainsaw video. smalleng.com
Nov 20, 2010 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Saw will start will chock out, when chock is
Your symptoms indicate a lean condition. Check to be sure the muffler and/or spark arrestor are open and unobstructed. If all the parts are installed properly and your mixture screws are between 1.5 and 2 complete turns OUT, the saw may possibly have leaking crankshaft seals. The saw would need a pressure/vaccuum test at a repair shop to verify this.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Bill
Feb 24, 2009 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
2,963 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
