Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Pressure arm doesnt lift properly
The pressure arm on my 50cd Wurlitzer One More Time doesn't lift properly when a cd is placed on the turntable or when the cd is finished, I just touch it lightly with my finger and it pops up to allow the cd onto the turntable and the same when the cd is rejected. The jukebox was disasembled to repair the laser and when put back some time later this fault occured, it maybe that a spring has gone missing, the service man who "repaired" it has disappeared leaving this problem
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The whole tray assembly pivots on a single point just under the clamp arm at vthe back. There is a circlip holding everything in place when the pivot comes up to lift the clamp arm. If that circlip is not assembled correctly (or missing) the clamp arm will not rise properly.
Dave F.
Posted on Jun 25, 2009
  • 38 Answers
SOUNDS LIKE A SPRING HAS NOT BEEN INSTALLED IN THE UNIT.
ALSO SEE IF HE BENT ANY PARTS ON THE LIFT COVER ON THE LASER PORTION OF THE JUKE. IF THAT WAS WHAT HE WORKED ON.
IF THE LIFT COVER (OVER THE LASER )
HAS BEEN BENT THAT CAN CAUSE THE PROBLEM.
Posted on Jun 10, 2009
  • DOCTOR FIX Jun 10, 2009
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Model- 1015CD Wurlitzer "One more
It sounds like a communication problem between the Selection & Credit Computer (SCC) and the CD Control unit, or perhaps a defective player (SCC is telling it to play, but it can't). There are different troubleshooting procedures, depending on which player version you have. Please email me and I'll give you a phone number where you can call me for further help
May 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
My 1015 will selects the same disc, then places it on the turntable. Turntable does not spin. The arm the picks the cd and places it back into it's slot. This happens continuously and the digital display...
There is most likely a problem with your K7 switch acuator. I have these in stock, and can help verify this with you over the phone. Please email me and I'll give you my phone number, tech@wurlitzer-ohio.com
Mar 06, 2011 | Wurlitzer Jukebox 1015 One More Time...
This is a problem is with the Wurlitzer 1015 One
Make sure the Service switch on the jukebox Credit Unit (computer) is in the off position.
It actually sounds like a Selection and Credit computer fault.
Apr 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a 1993 wurlitzer New York, New York jukebox. it has the same inters as a 1015 one more time. the problem i am having is with the cd gripper arm. it will take a cd from the cd carousal and place it...
I would suspect you have a lubrication (or more specifically lack of lubrication) problem. When the gripper arm is over the carrier, pick it up a couple of inches (as it moves to pickup a CD) and drop it. It should snap right back down. If it doesn't, it will not properly pickup and return CDs. You may be able to lubricate it to get it working again. For further information, you may email me, tech@wurlitzer-ohio.com.
Mar 15, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm frozen w/ one digit flashing 8 then E w/o top of E
At the far side of the white nylon gears at the base of the gripper arm is a small white 'duck bill' bracket, which clicks a microswitch when the gripper is over the carousel. When it breaks or comes loose it fails to click the microswitch and the arm doesnt stop.
Dave F.
Mar 11, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
96 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
