Question about Nintendo Wii Console
I can not install any wads i get error 2011 all the time
  • 3 Answers
Nintendo wii call 1-800-255-3700 they can help
Posted on Feb 24, 2009
Why is black ops not playing on my wii?
Maybe your disk is corrupted. Or try to use another loader like NeoGamma or WiiGator. Just Install the wad file with your wad manager. ;)
Dec 06, 2012 | Nintendo Wii Console
Tip
Wii soft mod guide
Wii SoftMod Guide 3.1 - 4.1
Before we start into the process, you will need an SD card, at most 2gb capacity. This SD card will need to be formatted into FAT32 format.
Note: If you are on Wii System Firware 3.1, 3.3 or 3.4 You need to be connected to the Internet, unless you know the proper steps to upgrade using the Wii System WAD and Firware Updater 4.1 which I may include later.
First, download this file pack. Wii SoftMod 3.1 - 4.1 Pack
Download Readme file here. Wii SoftMod Readme
Step 1. Install The Homebrew Channel & BootMii
1. Put all the files from ‘Wii SoftMod 3.1 - 4.1.rar’ onto the root of the SD Card.
2. Insert the SD card into Wii.
3. Go to Wii Options, then go to Data Management > Channels > SD Card, then you will get a message saying "Load boot.elf?" , select 'Yes' and the Hackmii installer will run. (Goto the Channels first, then insert card or your console might freeze)
4. Install Bootmii as boot2 if you can, if not then install it as an IOS then go back and install the Homebrew Channel.
Step 2. Install Recommended CIOS
1. Go to Homebrew channel and run Trucha Bug Restorer, load IOS36, press 1, read the warnings then select 'downgrade IOS15', select to load IOS from SD card then let it do its job, keep an eye on what it is doing and make sure you select 'load from sd card' when it asks & don't get any errors.
2. Run Trucha Bug Restorer again, this time select to load IOS15 on first screen using dpad left/right, then select the IOS36 menu & install patched (select 'yes' on all 3 patches) IOS36 to slot 36, again using IOS from SD card.
3. Run Trucha Bug Restorer again, load IOS36 and this time select restore IOS15.
4. Run cIOS38 r14 installer, select IOS36 as the one it should use and then select wad install.
5. If your Homebrew Channel flips upside down then continue with the guide and when completed reinstall the homebrew channel.
Step 3. Update System Menu (Only for 3.1, 3.3 or 3.4 Firmware) Note: Internet Connection needed
1. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1.
Step 4. The Final Step
1. Go to the Homebrew Channel and run Wad Manager 1.4 and load IOS249 (Default) and SD card.
2. Instal the following IOS.
* IOS38-64-v3610
* IOS50-64-v4889
* IOS53-64-v5149
* IOS55-64-v5149
* NeoGamma r8b17
Restart your console and your finished!
on Feb 18, 2010 | Video Game Consoles & Games
Tip
Wii - How to SoftMod, Guide.
This post will explain How to SoftMod Nintendo Wii on any firmware, Region and make its Homebrew enabler for play Wii games, backup, Homebrew applications on your wii, And all without needing a wii modchip!
Requirements: A SD card, (1GB should be enough for Installer and Backup), formatted to FAT32. Some SD card is not compatible to be used to backup the wii nand, but its work for use as boot2 of bootmii, so you might be need 2 different memory, for installation and nand backup.
Download: All files can be found **Here..!
*SD Card Pack
*cIOS38_rev14-Installer
*IOS60 Patched.
*Trucha Bug Restorer
*WAD Manager v1.4
*AnyRegion_Changer_v1_1b
*AnyTitleDeleterDB
*Backup Launcher WBKL
*Firmware Updater v4.1 -299Kb. (Need Wi-Fi connections).
*preloader v0.29 -214Kb. (OPTIONAL).
Installation Procedure:Adding Files.
  1. Extract ‘SD Card Pack’ and copy all contents to the root of SD Card, and copy a second of ‘IOS38-64-v3610.wad’ to ‘wad’ folder - ‘SD:/wad/’.
  2. Extract ‘cIOS38 rev14 Installer’, ‘Trucha Bug Restorer’, ‘WAD Manager’, ‘Any Region Changer’, and ‘Any Title Deleter’, into ‘apps’ folder - ‘SD:/apps/’.
  3. Extract ‘IOS60 Patched’ and ‘Backup Launcher WBKL’ into ‘wad’ folder - ‘SD:/wad/’
  4. Preloader is also an optional install, if you don't want it just skip.. Extract ‘Preloader’ into ‘apps’ folder. ‘SD:/apps/’.
  5. Extract ‘Firmware Updater v4.1’ into ‘apps’ folder. ‘SD:/apps/’. This updater require wi-fi connection, If you want to use offline updater, you will need wad updater (*.wad) and put its into ‘wad’ folder. IMPORTANT!! Make sure you have select the right one for your region..! E=Europe, J=Japan, U=USA, if you use a firmware from a different region, it will BRICK your Wii.!
Install BootMii & Homevrew Channel.Homevrew Channel is a channel on your wii menu that will allow you to put applications (homebrew) on your sd card and put them on your wii, this may include emulators, games, and installers.
Insert the SD card into Wii. then, Go to ‘Wii Options’ > ‘Data Management’ > ‘Channels’ > ‘SD Card’, then you will get a message saying ‘Load boot.elf?’, select ‘Yes’ and the Hackmii installer will run.
Press ‘A’ to continue, Install the ‘Homebrew Channel’ (HBC), and follow the on screen instructions. When done, the HBC will appear on wii channel.. Now go back and install ‘Bootmii’ as ‘boot2’ (recommended), if you can't install it, try different SD card. When it done, reboot your wii with it SD card, and wii will load into BootMii menu..
Backup Wii NandMaking a NAND Backup with Bootmii is highly recommended, it will recover your Wii from bricks. make sure there is at least 530MB free on SD Card.
Boot Wii into BootMii menu, if bootmii is installed as an IOS, go to the Homebrew Channel, press ‘home’ on your Wiimote then select ‘Launch Bootmii’.
Readmore...
on Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Fix camshaaft timming on 2004 dodge ram1500 47cui
For this problems,check the help links below,click the link to o through its troubleshooting procedure :-----Crankshaft and camshafts timing marks? http://technoanswers.blogspot.in/2012/02/crankshaft-and-camshafts-timing-marks.html---------- dual over cam timing mark details? http://technoanswers.blogspot.in/2012/02/saturn-vue-30-dual-over-cam-timing-mark.html---------- How to replace Adjustable Camshaft timing solenoid? http://technoanswers.blogspot.in/2012/02/how-to-replace-adjustable-camshaft.html------------ How to Inspect Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-camshaft.html
camshaft Timing specifications? http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
Crankshaft Front Seal? http://schematicsdiagram.blogspot.com/2011/12/crankshaft-front-seal.html
How test cam shaft? Testing Car Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-test-cam-shafttesting-car-camshaft.html
How to service Cam Shaft? Camshaft servicing? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-cam-shaft-camshaft.html
How to replace Camshaft? Replacing Vehicles Cam Shaft Assembly? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-camshaft-replacing.html
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 28, 2012 | 2004 Dodge Ram 1500
I cannot print. Always in the scree The waste ink absorber is almost full; What can I do Thanks for answering
Right at the bottom of the printer case, underneath the cartridge dock, there's a whole bunch of wadding/pads packed in to soak up excess ink.
These pads need to be taken out, cleaned, dried and replaced. Then you need to reset your printer.
I've just done this on a Pixma ip2000. Basically, all the casing unclips one way or another, all needs to come off, but you don't need to remove the cartridges.
When I say it all unclips, it does save for the main casing which clips and there's screws at the front to remove.
Once dismantled, check out the area behind and below the cartridge docking area, you should see the wadding. Rubber gloves time.
Remove all the wadding, mine came in 6 pieces from an "L" shaped tank, remember where each piece goes because they're different shapes. Wash clean and dry the wadding, then replace them.
I couldn't get one piece back in, just too awkward, so I left it out. Made no difference.
Then re-assemble your printer.
Then you need to reset your printer to remove the error message. (This works for many Canon printers, yours should be the same)
1) Re-connect your printer back to the power source.
2) Press and hold the Resume button.
3) Press and hold the Power button.
4) Release the Resume button.
5) Press and release the Resume button 2 times.
6) Release the Power button and wait for the green light to stop blinking.
7) Wait for initialization to complete.
8) Press resume. (Once for power down, twice for test, 3 for eprom info, 4 for inktank reset).
9) Press Power button to accept the reset.
Sep 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
HOW WE INSTALL AutoCAD 2011 ON WINDOW 7
how to install autocad 2011 step by step
Sep 09, 2010 | Autodesk AutoCAD 2010
Wii - installed a .wad now get black screen
I hate to scare you but that's not good. You might have bricked your Wii by installed a bad .WAD -- installing a bad WAD will most definitely brick your Wii. Hopefully you did a backup using BootMii before you did that and backed up your Wii's NAND. Thats the ONLY way you can restore your brick Wii from bad .WAD installs. Here's a few great guides that might help you unbrick your Wii.. good luck!
http://www.wiilovemario.com/The-most-up-to-date-Wii-Homebrew-and-Backup-tutorials-known-to-mankind
Sep 30, 2009 | Nintendo Wii Console
Can i unlock a nintendo wii console to play NTSC games
right u want to soft mod your wii it is realy easy to do this ist u need is an sd card
http://bannerbomb.qoid.us/aads/aad1f_v108.zip
http://www.yafaze.com/wii/files/4.0softmod.rar
Put the contents of both zips on your SD Card as it is in the zip, just drag all to SD Card.
Go to Data Management then choose Channels followed by SD
Choose "Yes" to load boot.dol
LoadMii will then load.
Press "A" on the WiiMote.
Go down to DowngraderIOS35.dol and run it by pressing "A" on the WiiMote.
Choose downgrade IOS35 and then let it go, then choose exit (ignore the patchmii and dvdx)
You'll be back in LoadMii now.
Go down and run Wad Manager 1.4 by pressing "A" on WiiMote.
Just select normal settings (don't change IOS)
Install IOS35.wad.
Exit Wad Manager 1.4 by pressing "HOME"
You'll be back in LoadMii.
Run Wad Manager again, Select IOS35 when it asked what IOS to use.
Install the CIOSv7.wad.
Press "Home" to exit.
Then Run Wad Manager again.
Tell it to use IOS249.
Install IOS36.wad, BUL3g.wad & HBC.wad
Sep 29, 2008 | Nintendo Wii Console
Can someone please help
Ok, the PSP emulator is a program that emulates the work of PSP on your computer, and take a portion of your PC's CPU to emulate the PSP's Processor. Or you can say it's a program that runs your PSP games through a window. To Run your "Doom on PSP" I can paste some text from the readme.txt inside this file: http://psp-news.dcemu.co.uk/files/doompspv005plus.zip Release Notes for Doom-PSP 0.05 plus: To Install fw 1.0 and 2.0(with loader) 1. Create Doom dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw10 into doom dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. fw 1.5 1. Create Doom dir under Games. 2. Create Doom% dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw15/Doom into doom dir. 5. copy eboot.pbp from fw15/Doom% into doom% dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. Then give us feedback. Play nice with your PSP. Goodluck
May 17, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
