Question about Homelite Garden
Chainsaw won't start. Can't pull starting cord out
I’ve had a Homelite 45cc 18” chainsaw for about 2 years. In those two years it’s done everything I’ve asked of it including starting very easily every time. I’ve been extremely happy with it. I cut some wood on Saturday without a single problem and then on Monday when I tried to start it, I couldn’t pull the rope out more than an 1” – 1 ½”. I took the starter cover off and checked to make sure the rope hadn’t come off. I also took out the spark plug which was dry. When the plug is out I am able to pull the rope out all the way and I can see the piston moving up and down. However, as soon as I put the plug back in it goes right back to me not being able to pull the rope out again. I know nothing about engines and I’m hoping that someone has experienced this sort of thing before me and can tell me what what’s wrong.
    Problem Solver:
  • 11 Answers
Thats a little strange.
Only thing that comes to mind is someone else had access to it and swapped out a plug that is too long for your short plug, Check plug type in owners manual.
maybe on sunday their 4 wheeler wouldn't start and this was quick fix.
Take off the chain cover or starter and see if it turns back and forth almost one full turn with a sudden stop at both ends of rotation. (Hitting plug)
if this is ok get back to me.
Bill
Posted on Feb 26, 2009
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
I need a manual for a Homelite chainsaw Where is
Hi calwolfe...
Go to the following website and download your manual, if it is among the list.
You did not get me a model so I did not have much to work with to find your user manual for your chainsaw.
Please take time to rate me
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Sep 10, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Have an xl 240, won't start. put fuel in carb and it runs, doesnt seem to get fuel from tank. How to fix this?
Check fuel line for obstruction first then you need to disassemble your carb a give a full cleaning maybe even rebuild it. Check out this link and watch the chainsaw video. smalleng.com
Nov 20, 2010 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Saw will start will chock out, when chock is
Your symptoms indicate a lean condition. Check to be sure the muffler and/or spark arrestor are open and unobstructed. If all the parts are installed properly and your mixture screws are between 1.5 and 2 complete turns OUT, the saw may possibly have leaking crankshaft seals. The saw would need a pressure/vaccuum test at a repair shop to verify this.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
394 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
