Question about ASUS Computers & Internet
Touch pad is none responsive but the laptop will work with mouse.
  • 903 Answers
Try uninistalling the touchpad in control panel>device manager. You will find it under pointing devices, reboot the computer and it should be picked up as new hardware and be reinstalled.
I hope this helps
Posted on Feb 24, 2009
  • Debs
    Debs Feb 24, 2009
    I should have added that you need to click on the + sign next to pointing devices right click on touchpad then choose uninstall
Milk was spilled on the touchpad of my laptop the cursor moves but it won't click
You need to replace the touch pad or you can connect an USB mouse to your laptop and not use the touch pad.
Mar 21, 2013 | Dell Inspiron Computers & Internet
Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
Once a mouse was attached the Acer Aspire 5532 touch-pad no longer works. When the mouse is disconnected the touch-pad still will not work. I do not see a toggle button to use to toggle between the mouse...
HI Diane,
Since you haven't provided the Windows Operating System version (XP/Vista/7 or other?), I'll have to provide the general scope of what you should try.
1. Go to the Control Panel and open up your Mouse section
2. Look through the different tabs until you find an option to either "Enable" your touchpad, or one that says the equivalent of "Disable Touchpad when external mouse or device is connected"
The idea is to accomplish your aim by working with the mouse settings provided for your system. Good luck and go easy on the "blue thumb". Please provide more specific information before a negative response.
Thanks
Aug 29, 2010 | Acer Aspire 4520-5582 Notebook
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
I want to adjust the sensitivity of my touch pad, but I cannot find any software that allows me to do so. The only pointer software and driver hardware apparent in control panel is for a mouse.
those mouse options, speed, buttons, tapping to click - should still apply to the touch pad - see if Have a look at a TAB called Pointer Options - that will enable you to slow and speed up the touch pad response
Apr 22, 2010 | HP Pavilion dv2742se Notebook
Netbook touch pad quit working after attaching a USB mouse
Go into the mouse options in the control panel and make sure that the touch pad is not disabled.
May 31, 2009 | ASUS Eee PC 900 Notebook
My Touch pad mouse doesn'e work
hi. if its a physical problem, try using a eraser with it and then clean the thing with the eraser. i do it on my my laptop and it works for me. so yeah.
May 20, 2009 | Compaq Computers & Internet
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Computers & Internet Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
