FixYa.com
Tags:
Sony Internal DVD Drive
Call for testers: acpica-unix-20021118.tar.gz
By LiZzIe - usenet poster
Hi all,
I've made patches for the latest ACPI CA snapshot between 20021002 and
20021118.
A lot of bugs are fixed, please check the change log at:
Please test them and feedback to if you find any
problems. I'll import them into src tree before RC1.
Thanks
To Unsubscribe: send mail to
with "unsubscribe freebsd-current" in the body of the message
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Brad
Brad - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
--TBNym+cBXeFsS4Vs
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
Content-Transfer-Encoding: quoted-printable
Thanks, that did the trick.
/me should try a little more before sending out mail.
- Christian
--=20
GPG Pub-Key : #
GPG Fingerprint: A5C8 2099 19FF AACA F41B B29B 6C76 178C A0ED 982D
GPG Key ID : 0xA0ED982D
--TBNym+cBXeFsS4Vs
Content-Type: application/pgp-signature
BEGIN PGP SIGNATURE
Version: GnuPG v1.2.0 (FreeBSD)
iD8DBQE94yrqbHYXjKDtmC0RAiWoAKC/7fWv8lxhweY0n4XjV9SUeWe1RwCgk7Hi
FtEraGZHBBfuPkbjmO+fZdM=
=i4/i
END PGP SIGNATURE
--TBNym+cBXeFsS4Vs--
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
OK, never mind. This is normal because your DSDT doesn't have
_S1_ object.
Name(\_S0_, Package(0x4) {
0x0,
0x0,
0x0,
0x0,
Name(\_S3_, Package(0x4) {
0x5,
0x5,
0x0,
0x0,
Name(\_S4_, Package(0x4) {
0x6,
0x6,
0x0,
0x0,
Name(\_S5_, Package(0x4) {
0x7,
0x7,
0x0,
0x0,
Instead of _S1_, you can specify _S3_ (or _S4_ if you setup for
hibernation properly) for ACPI configuration.
Please try:
# sysctl hw.acpi.sleep_button_state=S3
# sysctl hw.acpi.lid_switch_state=S3
# sysctl hw.acpi.standby_state=S3
Thanks
Solution #3
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
This is a multi-part message in MIME format.
010105080805080406020405
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I tested the patches on my Sony FX601.
The problem is still the machine starts resuming after suspending to S3,
but the display stays black.
I attached my dmesg output and the output from acpidump, ... there are a
lot of acpi related errors
bye,
Mitsuru IWASAKI schrieb:
Michael Bretterklieber -
JAWA Management Software GmbH - #
Liebenauer Hauptstr. 200 privat
A-8041 GRAZ GSM: ++43-(0)676-93 96 698
Tel: ++43-(0)316-403274-12 E-mail:
Fax: ++43-(0)316-403274-10 #
"...the number of UNIX installations has grown to 10, with more expected..."
- Dennis Ritchie and Ken Thompson, June 1972
name="dmes.txt"
Content-Disposition: inline;
filename="dmes.txt"
Copyright (c) 1992-2002 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD 5.0-CURRENT #1: Fri Nov 22 09:01:12 CET 2002
:/usr/obj/usr/src/sys/GENERIC
Preloaded elf kernel "/boot/kernel/kernel" at 0xc06ab000.
Preloaded elf module "/boot/kernel/acpi.ko" at 0xc06ab0a8.
Timecounter "i8254" frequency 1193182 Hz
Timecounter "TSC" frequency 1100044126 Hz
CPU: mobile AMD Duron(tm) (1100.04-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x662 Stepping = 2
Features=0x383f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV­,PAT,PSE36,MMX,FXSR,SSE AMD Features=0xffffffffc0400000<AMIE,DSP,3DNow! real memory = 268435456 (262144K bytes)
avail memory = 253554688 (247612K bytes)
Initializing GEOMetry subsystem
Pentium Pro MTRR support enabled
npx0: <math processor npx0: INT 16 interface
acpi0: <SONY K5 ACPI-0625: *** Info: GPE Block0 defined as GPE0 to GPE15
Using $PIR table, 6 entries at 0xc00fdf60
acpi0: power button is handled as a fixed feature programming model.
Timecounter "ACPI-safe" frequency 3579545 Hz
acpi_timer0: <32-bit timer at 3.579545MHz acpi_cpu0: <CPU acpi_tz0: <thermal zone acpi_button0: <Sleep Button pcib0: <ACPI Host-PCI bridge initial configuration
\\_SB_.PCI0.PIB_.LNKC irq 5: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.1.0
\\_SB_.PCI0.PIB_.LNKA irq 9: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.7.0
\\_SB_.PCI0.PIB_.LNKB irq 10: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.7.1
\\_SB_.PCI0.PIB_.LNKC irq 5: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.7.2
\\_SB_.PCI0.PIB_.LNKD irq 9: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.7.3
\\_SB_.PCI0.PIB_.LNKA irq 9: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.10.0
\\_SB_.PCI0.PIB_.LNKB irq 10: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.10.1
\\_SB_.PCI0.PIB_.LNKD irq 9: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.14.0
\\_SB_.PCI0.PIB_.LNKB irq 10: [ 3 4 5 7 9 10 11 12] low,level,sharable 0.16.0
before setting priority for links
before fixup boot-disabled links
after fixup boot-disabled links
arbitrated configuration
pci0: <ACPI PCI bus agp0: <VIA 82C8363 (Apollo KT133A) host to PCI bridge pcib1: <ACPI PCI-PCI bridge initial configuration
\\_SB_.PCI0.PIB_.LNKC irq 5: [ 3 4 5 7 9 10 11 12] low,level,sharable 1.0.0
pci1: <ACPI PCI bus pci1: <display, VGA isab0: <PCI-ISA bridge isa0: <ISA bus atapci0: <VIA 82C686 ATA100 controller atapci0: Correcting VIA config for southbridge data corruption bug
ata0: at 0x1f0 irq 14 on atapci0
ata1: at 0x170 irq 15 on atapci0
uhci0: <VIA 83C572 USB controller usb0: <VIA 83C572 USB controller usb0: USB revision 1.0
uhub0: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 2 ports with 2 removable, self powered
uhub0: port error, restarting port 1
uhub0: port error, giving up port 1
ukbd0: Tangtop Generic USBPS2, rev 1.10/0.01, addr 2, iclass 3/1
kbd1 at ukbd0
ums0: Tangtop Generic USBPS2, rev 1.10/0.01, addr 2, iclass 3/1
ums0: 3 buttons and Z dir.
uhub0: port error, restarting port 2
uhub0: port error, giving up port 2
ums1: Logitech USB Mouse, rev 1.10/6.10, addr 3, iclass 3/1
ums1: 3 buttons and Z dir.
uhci1: <VIA 83C572 USB controller usb1: <VIA 83C572 USB controller usb1: USB revision 1.0
uhub1: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub1: 2 ports with 2 removable, self powered
uhub1: port error, restarting port 1
uhub1: port error, giving up port 1
uhub1: port error, restarting port 2
uhub1: port error, giving up port 2
isab1: <PCI-ISA bridge pci0: <multimedia, audio pci0: <simple comms cbb0: <TI1420 PCI-CardBus Bridge cardbus0: <CardBus bus pccard0: <16-bit PCCard bus cbb1: <TI1420 PCI-CardBus Bridge cardbus1: <CardBus bus pccard1: <16-bit PCCard bus pci0: <serial bus, FireWire rl0: <RealTek 8139 10/100BaseTX rl0: Realtek 8139B detected. Warning, this may be unstable in autoselect mode
rl0: Ethernet address: 08:00:46:5a:c4:4b
miibus0: <MII bus rlphy0: <RealTek internal media interface rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
acpi_acad0: <AC adapter acpi_cmbat0: <Control method Battery acpi_cmbat1: <Control method Battery acpi_lid0: <Control Method Lid Switch fdc0: <enhanced floppy controller (i82077, NE72065 or clone) fdc0: FIFO enabled, 8 bytes threshold
fd0: <1440-KB 3.5" drive sio0 port 0x3f8-0x3ff irq 4 on acpi0
sio0: type 16550A
ppc0 port 0x778-0x77f,0x378-0x37f irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/8 bytes threshold
plip0: <PLIP network interface lpt0: <Printer lpt0: Interrupt-driven port
ppi0: <Parallel I/O atkbdc0: <Keyboard controller (i8042) atkbd0: <AT Keyboard kbd0 at atkbd0
psm0: <PS/2 Mouse psm0: model GlidePoint, device ID 0
acpi_ec0: <embedded controller orm0: <Option ROMs pmtimer0 on isa0
sc0: <System console sc0: VGA <16 virtual consoles, flags=0x300 vga0: <Generic ISA VGA Timecounters tick every 10.000 msec
acpi_cpu: CPU throttling enabled, 16 steps from 100% to 6.2%
system power profile changed to 'economy'
ad0: 19077MB <HITACHI_DK23DA-20 acd0: DVD-ROM <QSI DVD-ROM SDR-081 Mounting root from ufs:/dev/ad0s2a
ACPI-0432: *** Error: Handler for [EmbeddedControl] returned AE_ERROR
ACPI-1287: *** Error: Method execution failed, AE_ERROR
ACPI-1287: *** Error: Method execution failed, AE_AML_NO_RETURN_VALUE
system power profile changed to 'performance'
logo_saver: the console does not support M_VGA_CG320 ...
read more »
Solution #4
Not Rated (0)
Perkins
Rating: 0%, 0 votes
* De: John Baldwin < [ Subjecte: Re: Call for testers: acpica-unix-20021118.tar.gz ]
DSDT=0x3ffbf77
INT_MODEL=PIC
SCI_INT=9
SMI_CMD=0xb1, ACPI_ENABLE=0xf0, ACPI_DISABLE=0xf1, S4BIOS_REQ=0x0
PM1a_EVT_BLK=0x1000-0x1003
PM1a_CNT_BLK=0x1004-0x1005
PM2_CNT_BLK=0x1030-0x1030
PM2_TMR_BLK=0x1008-0x100b
PM2_GPE0_BLK=0x1018-0x101b
P_LVL2_LAT=200ms, P_LVL3_LAT=2000ms
FLUSH_SIZE=0, FLUSH_STRIDE=0
DUTY_OFFSET=1, DUTY_WIDTH=3
DAY_ALRM=72, MON_ALRM=73, CENTURY=50
Flags={WBINVD,PROC_C1,SLP_BUTTON,TMR_VAL_EXT}
Thanks!
juli.
Juli Mallett < OpenDarwin, Mono, FreeBSD Developer.
ircd-hybrid Developer, EFnet addict.
FreeBSD on MIPS-Anything on FreeBSD.
Solution #5
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
On 21-Nov-2002 Juli Mallett wrote:
Could you provide just the RSDT portion of your acpidump? Specifically the
section that srts with DSDT= and includes INT_MODEL=, etc.
John Baldwin < "Power Users Use the Power to Serve!" - #
Solution #6
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
* De: Mitsuru IWASAKI < [ Subjecte: Call for testers: acpica-unix-20021118.tar.gz ]
Well, my ACPI still doesn't work, here's a dmesg. But I do now get a longer
error.
FreeBSD 5.0-CURRENT #45: Thu Nov 21 15:36:15 CST 2002
:/usr/src/sys/i386/compile/LUNA
Preloaded elf kernel "/boot/kernel/kernel" at 0xc0547000.
Timecounter "TSC" frequency 474888664 Hz
CPU: AMD-K6(tm) 3D processor (474.89-MHz 586-class CPU)
Origin = "AuthenticAMD" Id = 0x58c Stepping = 12
Features=0x8021bf<FPU,VME,DE,PSE,TSC,MSR,MCE,CX8,PGE,MMX AMD Features=0xffffffff80000800<SYSCALL,3DNow! real memory = 67043328 (63 MB)
avail memory = 59457536 (56 MB)
Security policy loaded: TrustedBSD MAC/None (trustedbsd_mac_none)
K6-family MTRR support enabled (2 registers)
acpi0: <PTLTD RSDT ACPI-0483: *** Error: GPE0 block (GPE 0 to 15) overlaps the GPE1 block (GPE 0 to 15)
acpi0: could not enable ACPI: AE_BAD_VALUE
device_probe_and_attach: acpi0 attach returned 6
pcib0: <AcerLabs M1541 (Aladdin-V) PCI host bridge pci0: <PCI bus agp0: <Ali M1541 host to AGP bridge pcib1: <PCI-PCI bridge pci1: <PCI bus pci1: <display, VGA cbb0: <TI1225 PCI-CardBus Bridge cardbus0: <CardBus bus pccard0: <16-bit PCCard bus cbb1: <TI1225 PCI-CardBus Bridge cardbus1: <CardBus bus pccard1: <16-bit PCCard bus isab0: <PCI-ISA bridge isa0: <ISA bus pcm0: <Crystal Semiconductor CS4281 atapci0: <AcerLabs Aladdin ATA33 controller ata0: at 0x1f0 irq 14 on atapci0
pci0: <simple comms pci0: <bridge, PCI-unknown ohci0: <AcerLabs M5237 (Aladdin-V) USB controller usb0: OHCI version 1.0, legacy support
usb0: <AcerLabs M5237 (Aladdin-V) USB controller usb0: USB revision 1.0
uhub0: AcerLabs OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
orm0: <Option ROM atkbdc0: <Keyboard controller (i8042) atkbd0: <AT Keyboard fdc0: <Enhanced floppy controller (i82077, NE72065 or clone) fdc0: FIFO enabled, 8 bytes threshold
fd0: <1440-KB 3.5" drive ppc0: parallel port not found.
sc0: <System console sc0: VGA <16 virtual consoles, flags=0x300 sio0 at port 0x3f8-0x3ff irq 4 flags 0x10 on isa0
sio0: type 16550A
sio1: configured irq 3 not in bitmap of probed irqs 0
sio1: port may not be enabled
vga0: <Generic ISA VGA fb0 at vga0
speaker0: <PC speaker unknown: <PNP0303 unknown: <PNP0700 psmcpnp0: irq resource info is missing; assuming irq 12
unknown: <PNP0501 Timecounters tick every 10.000 msec
wi0: <WaveLAN/IEEE wi0: 802.11 address: 00:30:ab:14:0a:60
wi0: using RF:PRISM2 MAC:HFA3841 CARD:HWB3163-SST-flash
wi0: Intersil Firmware: Primary 0.03.00, Station 1.03.04
ad0: 4126MB <TOSHIBA MK4313MAT Mounting root from ufs:/dev/ad0s1a
Thanks,
juli.
Can you Help with these DVD Drives problems?
DVD Drives
Changing drives
We have a CD drive, would like... Answer This...
DVD Drives
instilization for drive
is there anyway you could give... Answer This...
DVD Drives
burning Mp4 files to DVD
Why can I only burn around 20... Answer This...
DVD Drives
D:\ is not accessible incorrect...
Every time I try to use my D:\... Answer This...
DVD Drives
slow data reading
my dvd writer does not read the... Answer This...
Repair Service
Find DVD Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
