Home | Sony | KV-27S20 27" TV | Sony model # KV3...
Sony KV-27S20 27" TV
Problem for Sony KV-27S20 27" TV
Sony model # KV32S42. The TV started flashing when
By scf_d on Feb 24, 2009
Sony model # KV32S42. The TV started flashing when first powering up. The flashing would continue 4 or 5 times before TV would eventually stay on. The last time I tried to turn it on I heard a dull thud and the screen stayed dark with no sound at all. Any ideas? Thanks
Solution #1
posted on May 05, 2009
Not Rated)
ginko
Rank: Guru  Sony Expert Televisions & Videos  Expert
Rating: 89%, 4933 votes
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Was this helpful?
Yes
No
Popular Solutions for Sony KV-27S20 27" TV
Questions and Unsolved Problems for Sony KV-27S20 27" TV
Do you recommend Sony KV-27S20 27" TV?
Answer
Answer
Sony WEGA tube 34" 4.5 years old. The picture hue is all green/yellow/blue - no red. When I... (More)
Answer
i have a hitachi 36 tube type tv that the picture is slowing geeting darker. even if i turn the... (More)
Answer
have a 42' tv and i can hear the pictrue but cant see it
Answer
I don't have remote control. How do I use capture (subtitle) function for deaf ?
Answer
I have a 32" (?) Sony TV that is 12 years old. It is a floor model that is incased in wood with... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KV-27S20 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
