Question about Olympus FE-330 Digital Camera
When i go 2 photo,s ive taken.then move the shutter button 2 the right 2 zoom in,then it lets me move the picture up down left or right.when ive got the picture i want,how do i save that picture.
    President:
  • 919 Answers
Unfortunately that image is not able to be saved that way. To zoom in closer to the image is only for viewing purposes it does not allow you to save the image that way. You would need to download the image to the computer to be able to save it in that close up format.
Posted on Mar 12, 2009
How do i delete a photo off olympusC5060
it's the button that has a trash can icon. just to the left of the thumbwheel that's under the shutter button
Jan 22, 2012 | Olympus Camedia C-5060 Wide Zoom Digital...
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
Hi I find my shutter speed is slow.. I take a picture of a slow moving object and by the time the photo is taken, the object has moved out of frame
You need to press the shutter button half-way and allow the camera to lock in the focus (it will beep) and then, when the moment is right, press the rest of the way....result....instant picture...no delay.
Oct 21, 2010 | Fuji FinePix A820 Digital Camera
How do I activate digital zoom on my canon S3IS
I believe there is a ring around the button the shutter button (the button you press to take the photos. Your sort of push it left or right (near or far). The digital zoom should activate after it goes past its optical zoom range. Push it only slightly to slow down the zoom process.
Aug 12, 2009 | Canon PowerShot S3 IS Digital Camera
Photos taken on zoom have white horizontal lines across them. Photos taken at normal zoom are OK.
Hi!
It sounds like that the shutter cable inside lens is partially broken. It moves with the lens while it zooms, so it could loose contact while stretched - when you have zoomed the lens. Z750 and Z850 have this problem with shutter cable - it breaks. The white horizontal lines are because shutter doesn't work. I'm afraid the cable will brake soon and pictures will be too bright with white horizontal lines even at normal zoom. It is considered a hard repair - the shutter part or whole lens unit has to be changed. You can contact your local Casio service center and ask the price, but it will probably be very high. I work in a Casio service center and new lens for this camera costs about 250$. It's not a good idea to put on used lens or shutter, as it will brake again sometime - it's just a matter of time. I suggest you get another camera.
Hope this helps!
Tom
Jul 30, 2009 | Casio Exilim EX-Z750 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Blurriness
This is a great camera! Are you using the focus guide to focus on your main subject. Move the camera until your main subject is in the bos ten depress the shutter button 1/2 way down to focus the subject. Leave you finger there at the focus point-You can then move the camera to take in more objects or people and gently push the shutter all the way down. Generally, the causes of out of focus photos are:
the camera in the wrong mode-just start with the general mode-usually a little camera symbol
do not change any settings-if you have go to the menu button and settings and go back to default settings
the focus feature of the camera 9explained above is not being used
You are too close to the subject (use the zoom instead)
You are experiencing camera movement by pressing on the shutter too hard or moving your hands. A tripod always works best.
You can go to www.panasonic.com and obtain a manual for your camera if you do not have it.
If your camera still gives you blurry photos, please get back to me with any info that might help- have you dropped it or gotten it wet or anything like that?
Thank you for using Fix YA and please don't forget to rate me!
Aug 18, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 19, 2007 | Canon PowerShot A95 Digital Camera
Miss all the action shots with this camera
The longest part of the shutter delay is caused by the autofocus mechanism. Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken. Using that technique will let you capture action shots. There is no way to improve shutter delay on any particular camera. The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus FE-330 Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
