Question about IBM Wheelwriter 30 Typewriter
Someone used the typewriter and hit some code in error.
Now the typewriter will not type anything. Everything appears to be working correctly however nothing prints on the paper.
  • Anonymous Mar 28, 2014
    It appears that the striker mechanism is not working. How can I make typewriter work?
  • IBM Master
  • 3,594 Answers
If it is in the delay print mode it will print when you hit ret. If this is not the case you probably need a print solenoid cap, they are available but a little tricky to install.
DickyO
Posted on Feb 24, 2009
What do I do when my typewriter types different letters and symbols than the keys being hit
Turn the machine off then on or hold down the "code" key and hit Q "reset" key to get the machine to type the correct keys. This usually happens because something interferes with the free rotation of the printwheel. Check to be sure the ribbon and corredtion tape are installed correctly and check to be sure none of the "fingers" on the printwheel are bent outward. If a finger is bent, bend it back. If everything looks okay, the board or power supply is going bad.
Feb 23, 2015 | Brother GX-6750 Typewriter
When typing numbers a strange symbol appears in it's place, not a code symbol or a cap symbol.
Hmm, I have a sd 670, and I have a button called KD II, and it makes symbols appear. If you have that key, hit code then hit it. That should bring you back you back to normal.
Jan 29, 2014 | Smith Corona SL 580 Electric Typewriter
What does RELOC key6 mean on Brotehr GX-6750? Not BOLD and not Backspace1/2. Just plain RELOC?
Relocate, on any typewriter, generally is used to take you back to where you left off typing. Example, you type a line and see an error at the beginning. You back space to correct it, hit relocate and it will return to where you stopped typing.
Did this help?
Mar 26, 2011 | IBM Wheelwriter 30 Typewriter
Every time I hit the space bar, it types a character,
Check to see if the printwheel is in correctly.
Mar 02, 2009 | Office Equipment & Supplies
Brother typewriter sx 4000
make sure the ribbon and correction tape are installed correctly between the metal fingers on the far side of the printwheel and the cardholder. make sure there is no forien objects in the P/W or anything touching the petals on the P/W. turn mach. off for 10 secounds then back on or just hold down the code key and hit the Q (reset) if it still doesn't work, it will need repair or replacement.
Nov 04, 2008 | Brother SX-4000 Typewriter
IBM Wheelwriter 3500
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
Oct 09, 2008 | IBM Wheelwriter 30 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Stuck in a Mode
http://www.scantracker.com/KansasCityrepairs.html
These guys are repairers so they may have extra copies.
IBM's Typewriter's site also has manual for sale for less than $20.
The typewriter seems to have a bad ribbon cartridge or a bad typing wheel. Take each one out and try to see if it will type normal. If one does, then you know to replace it.
Zabrina
Jan 08, 2008 | Office Equipment & Supplies
Random letters/correction tape
You must have damaged the Daisy Wheel when you were fitting c'tape..Fit another wheel..
Apr 10, 2007 | Brother SX-4000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
93 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
