Question about Bosch 24 in. SHU53 Built-in Dishwasher
My bosch shu5315 cycles fine but when finished water is not draining completely. checked screen-cleaned-and problem still exists. Is it the heater? If so how hard to replace?.Note: remaining water fills bottom of dishwasher to point of almost overflowing.
  • 27 Answers
Check your airgap by the faucet of your sink. usually a metal cylinder is the cap. then you might have tabs to press in, or the top of the airgap can unscrew. usually i find stuff in there. mostly fishbones.. otherwise make sure the holes towards the bottem left of your dishwasher tub under your filters arnt clogged up. sometimes calcium gets in there a clogs those holes to the drain pump.
if no airgap then check that hole to the disposer. reach your finger in there towards where the dishwasher drain line is coming in and make sure that isnt clogged up.
Posted on Mar 19, 2009
Water coming back into bosch dishwasher
Check the drain hose that goes into sink cabinet. It should loop up as high as it can go so that water from the sink or disposal doesn't siphon back into dw.
Apr 08, 2015 | Bosch Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Bosch wfl2000 machine works on every cycle apart from spin, washes drains etc but wont spin. Cheched brushes and removed and had motor tested all ok, belt fine, any ideas- Controller!!
are you sure its heating the water as it will not complete the wash cycle if the heater has failed, hence not getting to the spin cycle. try testing heater or see if water is warm coming out or glass warms up
May 31, 2011 | Washing Machines
Water is left when cycle is finished
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Mar 26, 2011 | Bosch Dishwashers
Bosch Dishwasher continuous fill/drain
Have same problem with 2 second cycling. I resolder at the point of heater relay. Thought I had solved the problem of running forever on 1. Now have this "new" problem that you have described.
Nov 11, 2009 | Bosch SHU5315UC Dishwasher
Washer will not spin and finish cycle.
on the lower rhs is a clean out door, use ascrew driver to spin the door loose and clean out the pump behind the door.
Jan 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
254 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
