Question about Kitchen Appliances - Others
The wire on garbage disposal is to short
The wire on my garbage disposal was to short so i need to add about one foot socan i use 16-3 plug to run my garbage disposal safely? the motor is a badger 5 1/2 horsepower
  • 8,197 Answers
I would use a 14/3 Gage wire as the smallest. !^ gage is to small.
Posted on Feb 27, 2009
Smelly garbage disposal
Patricia,
I would suggest putting some lemon juice in the disposal and let it sit for a short period of time and then run hot water down that drain while the disposal is running. Hope this helps!
May 21, 2015 | Garbage Disposals
Garbage disposal electrical shock.
Are you sure it wasn't a static electric shock, rather than AC? If you live in a dry climate, or in a cold climate without a humidifier, and you may have walked across a carpet, it could have been a spark of static electricity. Especially if it hasn't reoccured.
Nov 28, 2014 | Garbage Disposals
Voltage
Motor will run with 80% rated voltage that shows on nameplate.
Typical household water heater nameplate will show on side of disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe voltage that shows on side of device.
May 06, 2013 | In-Sink-Erator InSinkErator Evolution...
Garbage disposal is jammed kitchen aide kwd-200a
Use broomstick:
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Sep 07, 2012 | KitchenAid Batch Feed Garbage Disposal...
How to fix a leak from a garbage disposal?
Check location of leak. If from bottom, replace disposal
Aug 18, 2012 | KitchenAid Batch Feed Garbage Disposal...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
I installed a new garbage disposal. The way I connected electric to it was to just run a pigtail to a near by outlet. I put a switch between the outlet and the disposal. Whenever I try to turn it on it...
It sounds like you put in ordinary wall switch.
You use the word 'pigtail' which implies electrical knowledge, so without a photo it's hard to tell where the switch is shorting the circuit.
You need a single-pole switch with 2 screws and a ground screw.
If you use a 3-way switch, your wires are connected to dark screw and one of the brass screw
You have 2 wires running between receptacle and disposal.
The wall switch interrupts one wire. Not both wires.
So one wire from receptacle runs continuously to disposal.
The other wire is cut and one end attaches to a switch screw, the other end of the cut wire attaches on the other switch screw.
The bare ground wire connects to green screw.
Preferably the Hot wire is cut.
Nov 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kitchen Appliances - Others Logo
91 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
