Question about Delphi Roady XT XM Radio Receiver
XM radio overheats
We have an XM Radio - Delphi roady XT that we use for "musak" at our office. It plays through ceiling speakers and to people who call us and are put on hold. It's worked fine for a couple years. The other day, it quit working. When I examined the radio, I found that it was very hot. Both the radio and the a/c power supply were hot. The radio was hot enough that the LCD display was discolored. I let it cool down for a while and when I plugged it back in, it worked for a short while - until it heated up again. I have both a car type base and the home type base and swapping out that didn't make a difference. Which component do you suppose is the problem, the radio or the power supply?
    New Friend:
  • 168 Answers
The radio if it does not work in the car too. You can turn off the back light it may help it cool down press "menu" go to Display light hit select set it to 10 sec. press select again and try it
Posted on Mar 06, 2009
5 Suggested Answers
SOURCE: Delphi Roady XT Quit Working
This sounds like the problem I posted about the a/c adapter. The radio doesn't get enough power because the scr in the a/c adapter is failing.
Posted on May 14, 2007
Slinteriors
  • 8617 Answers
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Posted on Jan 24, 2008
Puterwiz82
  • 60 Answers
SOURCE: unit displays xm sat radio but will not tune to
Did you try reseating it in the cradle? Check the connections to the cable too
Posted on Jun 06, 2009
SOURCE: Delphi Roady xt, cassette adapter problem
I was thinking how can I trick the cassette into keeping the cassette in there because every time I put it in, it just came right back out
This is what I did
Go and find a real cassette and cut out a little piece of the cassette tape and set that aside
Every cassette is different so find a way to attach tape from a real cassette to the cassette part of the cassette adapter
You need to attach the tape so it is flat over the head of the cassette just like in a real cassette, which is the part where the music is transferred, once u get it over the head the cassette deck will think it is a real cassette and it will stay in the deck, the tape doesn't even need to be perfectly flat like in a real cassette tape, it can be all messed up and it will still work but flatter is probably better, so you are just tricking the deck into believing that it is a real cassette, it worked for me and hopefully it will work for you, tell me how it works out
Posted on Mar 10, 2010
My radio just recently goes up to 119 and several of the channels i listen too come up as updating....and won't play.
Give XM a call, since they merged the channel lineup has changed. Have them push a new activation signal to the unit, which should unlock the rest of the channels. However, the roady XT isn't exactly known for its reliability, so the receiver itself might be dead.
Sep 12, 2011 | Delphi Roady XT XM Radio Receiver
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Connection
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Feb 02, 2009 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Jul 20, 2007 | Belkin F5X007 XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
187 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
