Question about Teac P-988 Turntable
Hi All. Have a old Teac P9 Turntable based on DC Brushless motor. Its PLL controlled. However the speed is not constant, The PLL does not seem to lock the speed. I have the schematics and service manul. Need to know if someone had issues with PLL and the hints that might help. Thanks Karatzdi.. Niewbie on this site.
Hi there. Do you have a service manual of this Teac? Please let me know - I am searching for it with no results. Best.
Posted on Dec 19, 2010
I have a problem with dc motor on a sanyo tp1010 turntable
It could be a cold solder, a bad capacitor or regulator on the motor dc board.
Mar 13, 2014 | Audio Players & Recorders
I have a sansui FR-D25 automatic pll dc servo turntable. it hasnt been used in a couple of years due to a broken stylus. i have purchased a new one but now the metal plate sounds like its grating on the...
You will have to remove the bottom cover and pull the center post off. There is a set screw that holds it in place. Once removed you will need to clean the hole out of dirty grease and oil with a q-tip and alcohol. Then put some new oil in the hole. Just a small amount. Sewing machine or turntable oil or similar. Not motor oil! When put back together that will cause the platter to rise up and away from the base. You may also check the plastic gears under platter attached to the post to see if the are broken or cracked. If it is you have a major problem and it will need to be replaced with a donor part.
Aug 22, 2013 | Audio Players & Recorders
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
Canon clc3900 error e013-0002
Hi
In most cases that means that you need to clean/ replace waste toner container, but in worst case scenario:
E013
Cause • Waste toner feeding motor (faulty)
• Waste toner feeding screw (rotation fault)
• DC controller PCB (faulty)
Description
0001 The rotation speed of the waste toner feeding motor has deviated
from a specific value for 0.1 sec or more (PLL signal ‘0’).
0002 The waste toner lock detection switch (SW4) has been pressed for
0.1 sec or more
Aug 28, 2010 | Canon CLC 5100 Copier
Teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Oct 23, 2009 | Teac GF-650 Turntable
My TEAC P688 is stuck in chipmunk mode for a large record - how do I slow it down?
Sometimes on the base of the turntable (under side) there are two presets one for the 45 speed and one for the 33. They might be hidden under a label or something. You might even have to go inside to find them. Anyway a small flat head screwdriver inserted in it should adjust the speed. You might have to work out which controls 33 speed. And of course if it is below you will have to figure out how to adjust it with a record playing. "Get out and get under!!!!" as they said about cars!
Jun 28, 2009 | Teac P-A688 Turntable
Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Nov 24, 2008 | Teac AG-V1050 Receiver
Turntable not turning to play record............. power on............ please help my email address - diatmesa@aol.com
This could be many things like the following>
If its a direct drive turntable the motor could be "blown",
or motor electonic speed controller burnt out.
If its a belt drive turntable then the belt could be broken
or stretched and is slipping, or the belt can have dropped of a drive pullety.
Also there are speed control mechanisms to adjust the final speed of the
turntable to the recorded speed of the record like 331/3rpm, 45rpm 75rpm
These speed reducing mechanisims can slip and cause the turntable not to turn..
There are also other mechanical bits that slide and push against each other,
and these can get sticky and the friction increases so much that the power
from the motor drive causes the belts to slip, so you need to identify if a
friction problem exists as well..
If you are carefull you can look your self and find out which one of the above it is.
Be warned there are lethal voltages inside the turntable which can kill you....
so please dont have the power on when making any inspection or adjustments.
Cheers From YUBEUT..
Jul 22, 2008 | Teac GF-350 CD Shelf System
Pioneer PL-300 Turntable plays records too slow
i think it is a belt driver table. you can find a replacement belt maybe. but if it is servo controlled motor driven then adjustments to sped setting has to be done.
May 03, 2008 | Audio Players & Recorders
Teac P-988 Turntable Logo
634 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
