Question about Whirlpool LGR3624JQ Gas Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
I have a Kirkland Costco Gas Dryer. My problems with dryer are: Everythig works except it does not get hot enough. It does get warm when it spins around, but not hot enough to dry the clothes. What could this be?
You need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Posted on Feb 25, 2009
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
The dryer heats up, but not hot enough to dry the clothes. Have cleaned all the vents and have good air flow.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 16, 2010 | LG DLE5932W Electric Dryer
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
Dryer does not get hot enough to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | GE DBXR463EDWW Electric Dryer
Dryer is not heating enough to dry clothing. The problem started with the electric braker box switch triped i had to replace it, dryer would turn on but no blower, I took a look at it and found some...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
87gh
Dec 09, 2009 | Estate TGDS740JQ Gas Dryer
Dryer heats up ands pins, but it takes forever to
Hi, First thing to check is the 4" venting to the outside. Make sure it is free of any lint and that there are no kinks in the hose. If this is a gas dryer, the couls on top if the gas valve could be getting over heated and not opening the gas valve later in the cycle so there will be no heat.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
481 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
