Question about HP Pavilion dv1000 Notebook
After the initial BIOS checkup, this error came up Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 PXE-E61: Media Test Failure, check cable PXE-MOF: Exiting PXE ROM what is this code and how do I fix it? Thanks.
  • helloly99 Feb 24, 2009
    Ok, I just tried that option in the bios, save and exit. After that, it doesn't show that message anymore but it shows a blank screen with cursor on the upper left corner and forever that way... The strange thing is I don't have the option of which one boot first but I do have the option to disable the LAN or Ethernet port.
    Thanks for your quick answers...
  • 2cvha Feb 26, 2009
    When I boot up, I get "Media Test Failure, check cable," "Exiting PXE ROM."
  • HP Master
  • 4,806 Answers
Hi there.
the laptop is trying to boot from the LAN (ethernet port)
Go into the bios and set the first boot device to the HDD, save the changes and exit, the PC will restart and boot from the hard drive.
Good luck and thanks for using Fixya!!!
Posted on Feb 24, 2009
  • Rezza BorneoZ Oct 26, 2012
    setting incorrect values may cause system boot failure: Load setup default values to recover, sy sudah mencoba ikuti instruksi yang tertulis tersebut, lalu saya "press" (f10) untuk menyimpan perubahan dan keluar, lalu laptop restart, namun pada layar kembali muncul tulisan : press (f2) go to setup, jika terlambat untuk press (f2) maka yang muncul pada layar adalah tulisan : (baris pertama) : BOOTMGR is missing, (baris kedua) : Press Ctrl+Alt+Del to restart, (baris ketiga) : cursor berkedip-kedip, lalu saya coba ikuti instruksi, tapi tetap kembali lagi pada hal serupa
  • 447 Answers
It looks like your machine is trying to use the network boot function, go into the bios and change the boot order so that your hard drive is the first boot device...
Operating system not found
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | Dell Inspiron 910 Laptop/notebook Black
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
PXE-E61 : media test failure, check For Realtek rtl8139 (x)/8130/810x PCI fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure,check cable PXE-M0F:EXITING PXE ROM
Are you on a company network ?
As I said if you are, then booting from a network may be part of your company system.
If it is just a home computer then you have other issues which could range from something as simple as a faulty hard drive cable to a dead hard drive.
If it is a company computer on a full lan then turn boot from network back on and see if it will boot. if not then te server that has the boot source may have an error or the lan may have issues.
Nov 01, 2011 | Computers & Internet
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media...
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Nov 08, 2010 | Acer Aspire 5100 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
HP Pavilion dv1000 Notebook Logo
462 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
