SATA driver for compaq presario v3000
I need the SATA driver for compaq presario v3000 which doesn't need floppy disk to extract the driver files..
  • Anonymous Feb 25, 2009
    Thanks for the response.. This is the exe file to install on the PC but I need the extracted file which I can burn with XP SP2 bootable CD and then I can install it on the laptop.. I am getting the files but these can be extracted on floppy disk which I do not have with me...
    Thanks
  • 4,806 Answers
Hi there.
What you need is Intel matrix storage manger for sata drives, go here read the info and download the drivers you need:
http://www.intel.com/support/chipsets/imsm/
Good luck and thanks for using Fixya!!
Posted on Feb 24, 2009
Can't download and can't install sound card as well as sound audio for compaq presario V3000
Be sure internet connection is stable to be able to download the driver you want.
COMPAQ PRESARIO V3000 DRIVER DOWNLOAD
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35682.exe
Platform: Windows XP/Vista x32
File size: 1423.36 KB
* Just click the file and install it on you computer.
Aug 31, 2011 | Compaq Audio card Sound Card
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
WATS THE PROCEDURE OF INSTALLED SATA DRIVER ON P5RD1-VM?
put the one end SATA cable to the HD and other end to motherboard then connect the sata power cable to the hd as well.
Sep 15, 2009 | ASUS P5RD1-VM Motherboard
HOW TO INSTALL XP IN COMPAQ PRESARIO CQ40-108TU
download sata driver from intel site
extract file into floppy
attach usb floppy drive on the laptop
during installation press f6 to install sata driver
Sep 01, 2009 | Compaq Presario Notebook
Sata drives for windows xp
Go here and download Matrix Storage Manger for sata drives, you have to select your OS first >>>>>>
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
Once downloaded you have to make a floppy disk or a bootable USB drive so make sure you read all the information first before performing the data transfer to the floppy/USB.
Once your happy that the files are on the media and in the USB port or floppy set the XP install going and watch the screen for the F6 prompt, it will be at the bottom right hand side of the screen and you have to be quick to install the third party drivers.
Good luck.
Jun 28, 2009 | HP Compaq Presario V6700TX Notebook
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Why not win xp load in compaq presario cq40
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
Here is the link for SATA driver:
http://downloadmirror.intel.com/16759/eng/f6flpy32_85.zip
Check the following document to install SATA dirver without using the floppy drive:
http://www.scribd.com/doc/4864999/sata
Jan 22, 2009 | Microsoft Windows Vista Home Premium with...
Blue screen comes
dear sir
for hp laptop they told that this laptopr only support windows vista but if u need to install windows xp u hav to make a sata or scsi drvier disk or cd for making cd u have to download a software call "Nlite" it's a softwaere to make a bootable cd with sata driver or u need to install from floppy u have to perchase or rented usb floppy drvier it's help u....:)
thanks
please vote
jo_chinmay
Jan 05, 2009 | Compaq Presario Notebook
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Computers & Internet Logo
430 people viewed this question
David Payne
David Payne
