Question about MTX Thunder 801D Car Audio Amplifier
MTX Thunder 801 D amp wont push any bass but turns on
I had amp now for about a month. wrkd great at first but then just gave out no sound. still turns on. had it ran to 2 12" kicker cvrs at 2ohms for 400rms each sub. subs still work. any ideas?
  • 2 more comments
  • SactownKid Feb 27, 2009
    subs are 400rms eacha nd fuses are good
    ok so i opened the amp up and think i found out where its burned, just dont know what to do. it says FET602 next to where its burned so???? here are pix if it helps
  • Erik Anthonsen
    Erik Anthonsen May 11, 2010
    check the fuses on the amp?
  • King3132 May 11, 2010
    you may have burned out the amp..how many watts are your subs?
2 Suggested Answers
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
  • 547 Answers
SOURCE: i have two four ohm
Wire the kickers in parallel -- hook the positive from each speaker to the positive on the amp, and the negative from each speaker to the negative on the amp.
This will present a 2 ohm load to the amp, and it's rated down to 2 ohms.
Posted on Jan 30, 2010
My mtx 1000xd will turn on but makes a sound inside near the circle donut looking with(lots of wires soldered) and where my ground is to the trunk bolt and even in side speakers. It will not power my...
sounds like you may have a bad torroid (the donut looking thing). you may also have a bad ground connection. make sure you have completely bare metal where the ground connection is. you need a very clean connection.
Oct 05, 2010 | MTX X Thunder 1000XD Car Amp
What is the long volume/bass control"s proper name.
the Control you are talking about is an External Bass Control also known as EBC knob you can probably find one at MTX.com or crutchfield.com or any authorized MTX dealer. Please vote and leave high marks. Thank you
Aug 03, 2010 | MTX Thunder 1501D Car Audio Amplifier
Amp and sub have been working great together then all of a sudden the amp is not putting out enough power to push the sub. MTX Thunder 311D
check to see if one of the RCA cables is unplugged or bad. check the gain check the sub level control on the deck if yours has one.
May 19, 2010 | MTX Thunder 311D Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Mtx 801d amp turns on but no bass just high pitch sound sub is fine
if theres a switch on ur amp that says LPF Full or HPF put it on LPF for low pass frequencies
Mar 16, 2010 | MTX Thunder 801D Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
When i plug the phonejack style bass controller in all the bass quits and as soon as i unplug it the bass come back instantly. also, next to the spot where you plug the bass controller to the amp there is...
I am guessing the bass control is just a potentiometer that you plug in. It could be open and that is why the bass dies. As far as the switch goes, I am not familiar with the amp but it sounds like a crossover between low frequency and subsonic frequency.
Dec 16, 2009 | MTX Thunder 801D Car Audio Amplifier
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder 801D Car Audio Amplifier Logo
658 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
