Question about Saeco Vienna De Luxe Espresso Machine
When I brew a cup of coffee, the water does not come out, instead it leaks out on to the counter. Does anyone have a suggestions?
  • Anonymous Mar 01, 2009
    Water is not coming out and I am discovering a leak on the counter. Took the machine apart, cleaned all parts. Still happening,
  • 3 Answers
This happened to me too.  When you take out the brew group there is a small spout that looks like a D on it's belly.  Clean this out and it should solve your problem.
Posted on Mar 14, 2009
    Problem Solver:
  • 8 Answers
Hello clean where the hot water hit the coffee thanks
Posted on Feb 24, 2009
Leaking water
If it's clean water which runs out, check the hoses going from the water tank to the pump then through the boiler to the brew group. If coffee is running out instead, then it's the spout going from the brew group to the cup. I know Saeco's not Juras but they all function the same way.
Mar 23, 2013 | Capresso Jura-13204 Impressa E9 Automatic...
Keurig b70 water tank leaks out all over the counter
Shut-off valve failed, retry a second time and it will reset accordingly.
Dec 31, 2012 | Keurig Platinum B70 Coffee Maker
B40 WR Keurig shooting out water instead of brewing
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle
Dec 26, 2012 | Keurig Special Edition B60 Coffee Maker
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Feb 10, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Mar 14, 2009 | Keurig B70 Coffee Maker
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaks everywhere
Make sure the lid is on the caraffe and just try to run plain water through. Although, it sounds like you might actually have a crack/leak. Return to store if possible or call Cuisianrt if it really is leaking.
Dec 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
173 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
