hi i got a buffalo tb external hardrive and the pc wont recognise it now after i transfered alot of data when the pc froze and i had to turn pc off mid transfer . please can you help
It is probable that since the transfer did not complete, the data on the external drive will be corrupt.
Uninstall the external drive then reinstall and format the ext drive.
You should then be able to begin the data transfer process again.
It just sounds like bad luck that your pc froze mid transfer. When you try again, do not use the pc for any other uses until the transfer has completed.
Regards and let me know if this works for you.
Was this helpful?
Yes
No
Popular Solutions for Buffalo Technology 250 GB Hard
Imation Apollo 320 gb hard disk was fine..suddenly, the system reads it..shows occupied space but no...
(More)
Imation Apollo 320 gb hard disk was fine..suddenly, the system reads it..shows occupied space but no file is accesible USBCP[æ . THIS NAME APPEARS alongwith a shortcut icon to D drive..PLEASE HELP..!!!!
I have an old MaxtorD740-6L 40gb AT disk drive which I want to fit into my new computer. I am unsure...
(More)
I have an old MaxtorD740-6L 40gb AT disk drive which I want to fit into my new computer. I am unsure as to which pins to fix the jumper to. There are four pairs of pins and at the moment the jumper is in the 3rd pair from the power plug. There are no diagrams or markings on the drive. Thanks Andy
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it...
(More)
I have used my Buffalo HD-HC250 external hard drive for a year with no problems. Now when I turn it on my computer system freezes. It wont do anything until I disconnect the hard drive or turn it off. When I turn it off my system immediately starts to work again. I downloaded a driver detective that says the driver is up to date. Any suggestions?
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and...
(More)
I have a Buffalo HD-HB250U2-WR drive and when I connect it to power and my desktop, the red and green LEDs turn on, but after 30 seconds or so the Green LED turns off and I am not able to see the drive (no error messages of any sort). Any help will be appreciate it. Jay
