Question about BenQ FP71G 17" LCD Monitor
I HAVE A PROBLEM WITH 19in NO DISPLAY IMAGE
SOME ONE HELP ME, THE LED IS ON GREEN BUT THATS ALL
DISPLAY BLACK AND THE BOARD PRODUCE NOISE
  • soft_button Mar 29, 2009
    I have the same problem. I boot the computer and the screen works for about a second, then it goes black, but the LED lamp is still green. I reboot the screen again and same thing happens, it goes on for about a second then it turns off. I am running the computer on the TV now.
    HELP ME !!
    Thanks in advance
    The Screen is a "BENQ T701"
    Problem Solver:
  • 13 Answers
It is due to shorted transistors and fuse. Get all the parts to DIY here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=220486136668
Posted on Sep 30, 2009
Yes, i fixed mine! I forgot to say that the power-on button was broken. So after suffering so long a pressed the buttin in untill it kind of disappeared. It might have been blocking something, i dont know.
So with no power on button it works fine, dont know if this is a good solution, but it worked for me !
Posted on Mar 29, 2009
Sagem axium hd-l32t/1 Display Problem??!!
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 05, 2014 | Televison & Video
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Why the computer doesn't turning on but the green light is lighted
You may want to verify if the computer is the one that do not turn on. Please check if you see the fan on your computer is working and the LED in the mother board is lit.
IF the computer is working and no display on the monitor, despite seeing a green light on the monitor display, this means that monitor is well connected and communicating well with the cpu. Better check the inverter light on the monitor. Replace busted lights. These are responsible for the image you see in your lcd monitor. If the inverter lights are busted then you'll see only black screen.
Jul 09, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
No image -- monitor remains black
Without any instruments to check it with, substitution is the best test; in other words connect the monitor to another system for a minute or two and/or a different monitor to your system. (If you can do either, don't do 'hot' swaps, turn everything off and then back on again.)
If you've noticed it; you may have seen that the LED flashes if the monitor is left on and the system shut down. Removing the VGA cable from the back of your system (or the monitor if it is separable) should produce the same result; flashing LED. If this is the case, then your video source from the system (on-board of add-on) has failed. If the video chipset on the motherboard has failed, it can be disabled and replaced by an add-in board for a few dollars.
Oct 12, 2009 | Acer AL1916ASD (Silver) Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Black screen flashing power led
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
May 08, 2009 | Computers & Internet
Front pannel header
if you have retsart / on - off and hdd led thats all you need to run the pc leave the others off.
hope this helps
Jan 03, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
BenQ FP71G 17" LCD Monitor Logo
645 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
