Question about Denon S-301
Can't view jpeg pictures from cd-r disc or usb memory card
Denon S-301 system seems to read cd and usb storage stick I'm using as it shows my picture folders on monitor. However, scroll and push/enter button on remote won't let me move to a specific folder or open. Even if I press the Help button on remote with nothing in tray or usb port, while the options including Setup appear on my monitor, I can't scroll to any particular option. Not sure if my scroll and push/enter buttons are malfunctioning or whether I have to do something in particular to enable these buttons.
SOURCE: Wont play CD's
saurus
please let us know if you get through to denon. I have been on hold as well for some time. Good to know that the problem is not unique but i hope there is an easy solution.
Posted on Dec 19, 2007
johnychel
  • 796 Answers
SOURCE: Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Posted on Jul 13, 2008
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Posted on Sep 11, 2008
  • 4 Answers
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Posted on Jun 14, 2009
  • 133 Answers
SOURCE: Denon DVD 910 won't power up. Light goes off then on.
Possibly a power supply problem, not enough power.
Could be these:
- dried up filter capacitors (electrolytic) - these include: main filter capacitor (the biggest one),
any final filter capacitors at each voltage output section, also at the oscillator end.
Check for any blown up, leaked or (partially) shorted capacitors.
- burnt out components (resistors, diodes).
Replace these (assuming you can still determine the proper value or type).
- poor solder contacts.
Remove the old solder and resolder the pins.
Dried, leaked or blown up capacitors may cause the power supply to crash down (or cycle with very low power output).
Burnt out components may act as a short circuit line, a change in conductivity (resistance) or as an infinite resistance (open contacts).
Poor solder contacts (so called "cold contacts") originate from bad soldering (at the factory), being further loosened by component overheating and tensile stresses (moving your equipement from place to place causes the circuit board to bend a little bit each time, and this, in turn loosens the solder contacts even further, causeing more overheating which may melt the solder, and so on).
You can tell a poor solder contact from a good one: bad ones will have a circular crack in the solder around the pin - try moving the pin a bit with a pair of tweezers - if it moves, there's your bad contact (you'll need a good light source and possibly a magnifying lens to spot these).
hopefuly you can get closer to a solution using these hints.
regards
3rq8 (Triarcuate)
Posted on Jul 14, 2009
Badly formatted Photos
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer.
Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
May 19, 2013 | Motorola Mobility Cliq 2 II MB611 MOTOBLUR...
I have a datatraveler 4gb stick how many photo will it hold
That is not exactly to calculate. It depends on the stored image sizeand quality.
Small pictures could be 400KB a piece, but large ones easily can go up to 6GB
a piece. If you know thye avaerage size of your pictures, you can calculate it.
Aug 28, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to load pictures to the frame
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
Jan 24, 2011 | Kodak EasyShare SV811 (8858946) Digital...
Memory card has a problem after taking important pictures.. displays reinsert memory stick error and wont read on computer either... any idea if photos can be recovered?
Make sure the memory contacts show up a visible clarity. If there is no detection in any of the card readers, inthe camera and inthe PC, it seems likely that your card has some errors on it,
If the card is detecting the memory but is not showing any pictures, the use a file search in the search mode with the drive selected for pictures/images.
If not it will be best to have it checked with a photo studio to concur the findings since you have important images on it.
Sep 23, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Computer cannot read card to download pcitures
Try using a separate card reader to download your pictures to a folder you create on your desktop.
Sep 16, 2009 | Cameras
Can pictures be downloaded from a computer to a psp
yah they can and its easy and take 2 mins. so just
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Tips:
  1. You can view jpeg, tiff, gif, png and bmp files on a PSP with firmware version 2.00 or higher. If your machine has firmware version 1.5, you can only view jpeg files. (To find out what version your PSP has, follow the tutorial linked below.)
  2. With recent firmwares, you can create subfolders inside the "PHOTO" or "PICTURE" folder, but do not create subfolders within other subfolders. so just follow this and ur good to go! good luck!
Jul 16, 2009 | Sony PlayStation Portable (PSP) Console
Computer won't read memory stick
SCMG - You won't be inserting it into your modem. But if the card fits snuggly and it seems to fit right, then you're probably where you need to be.
For all of you - it may be easier to connect the camera directly to the computer to download the pictures. All cameras come with the appropriate cable to connect the camera to a USB port. All you need to do is make the connection and then put the camera into "review" mode to view the pictures and Windows should automatically see the camera and ask if you want to download the pictures off of it.
Jan 07, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Worked for some
hello,
what operating system are you using? 98se, Xp or vista?
the usb change on your camera to mass storage works good with XP & Vsta.
if selected, you wont see scanner and camera wizard ever again.
when pugging your camera into your pc, the autorun window pops up like you just plugged in a USB jump drive in.
on view file you can drag the whole folder onto your desktop from the camera and rename the folder once done.
if the photos are showing up unable to view photo, file could be corrupt.
ive seen bad memory cards do this. then try another card.
good luck.
Aug 14, 2008 | Nikon Coolpix L11 Digital Camera
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Denon S-301 Logo
332 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
