Question about Panasonic PanaFax UF-8000 Laser Fax
User name an password required
I need to change the IP address of the PANAFAX UF-8000 but I am propmted for a password to do so.
What is the default password for the device?
    Genius:
  • 2,120 Answers
There is none. Try the action below:
press
function
7
monitor key slowly 4 times
6
Scroll down to password clear
set
stop
If that doesn't work, choose SHIPMENT SET
set
wait for machine to initialize
Posted on Feb 24, 2009
Loading software for network asking for IP address
Usually you can run a report on the printer that will show you the IP address it is using.
Mar 26, 2014 | Panasonic UF-8200 Panafax Panafax UF-8200...
Uf 9000 ip address
Just wondering if you've found a solution. I'm trying to do the same thing on our uf-9000. Any help would be appreciated.
Panasonic technical support is not good.
Oct 21, 2013 | Panasonic Panafax UF-9000 All-In-One Laser...
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How do you flush the panafax 8000 memory?
Your killing a fly with a sledge hammer. If you do a ALL JOB clear from test mode 6 instead of SHIPMENT SET... you wont loose all your one-touches or fax parameter settings.
Aug 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
SPEED DIAL
Press
Function
72
set
touch yellow keyboard key like 01
enter fax number
set
enter name
set
stop
Mar 27, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Email problems on Panafax UF-8000
you need a IFAX/email key "small little electronic board" installed on the main board it does not come as default so you need to talk to your dealer about this option
Nov 20, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
379 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
