Question about Onkyo TX-DS696 Receiver
Have to jar the unit to power on and only works with sound modes
It used to shut off on its own and was finicky on when it would allow me to turn it back on and some of the sound modes worked. I took it apart and looked it over for any visible issues. I was able to shock it back to on and initially all the sound modes worked. None of the sound modes work now and the box still needs to be shocked most of the time to power on
  • 151 Answers
You have a soft ware problem saw this a couple of times, return the amp to your dealer to send back to ONKYO for repair.
CABLE GUY.
Posted on Feb 24, 2009
Left speaker is very quiet
This may be a capacitor problem, evaluate and replace if bad.
Feb 12, 2014 | Harmon Kardon AVR 700 A 5.1-channel...
Dropped camera and now it won't turn on...
Unfortunately, digital cameras are sensitive, finicky little things. As with anything you drop, you run the risk of jarring something up inside that the camera needs to work. You might have cracked the screen or jammed the lens mechanism. It isn't good in any case, so I'd suggest taking your camera to a shop to have a professional look at it. Good luck!
Mar 13, 2011 | Nikon COOLPIX S630 Digital Camera
Indoor unit freezes up, turn the mode button to the fan only to thaw out the indoor unit but the outdoor unit runs, What should I look for?
If the outdoor unit is not shutting off, your indoor coil will freeze up when the thermostat "satisfies" and shuts off the blower. The most common cause of a non-stop outdoor unit is the contactor. This part is usually black or brown in color. The line voltage wires that come from the service disconnect to the outdoor unit hook up directly to this contactor. If you shut all the power off (circuit breakers), the outdoor unit will shut off. You might be able to tap on the contactor to "free" it. This might allow the unit to work for a little while, but 99 times out of 100, once the contactor starts sticking, it will continue to stick. Replace the Contactor. Extra precaution needs to be taken as there are two seperate voltage sources......240 volts from your circuit breaker box and 24 volts from the air handler. You should use a voltage tester prior to performing any electrical work.
http://www.youtube.com/watch?v=lywcF7Lt2n0
I hope you found this information helpful.
Good Luck! :-)
Mar 08, 2010 | Heating & Cooling
When I turn on my camera the screen is black. It doesn't allow me to focus on something so I can take a picture.
objective lens shut. sounds drastic but bang it against the palm of your hand while its on. that may jar it loose.
Jan 14, 2010 | Canon PowerShot A75 Digital Camera
When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
No home theater sound
Bad speaker wiring.
Internal fault.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
Power turns off
Bad speaker wiring.
Internal fault.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Bad speaker wiring.
Internal fault.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Onkyo TX-DS696 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
