Question about Microsoft Windows XP Home Edition
Windows xp slow internet explorer slow c:drive
I Have run Disk Cleanup and Disk Defragmenter.
All photos are on an outside drive
Use Verizon DSL
Please advise.
Thankyou
  • bsevinc May 11, 2010
    Got to the following address and check your internet speed. It'll tell you what speed is your connection, like dial up, dsl, or T1. Let me know what speed you are running.
    http://www.internetfrog.com
    Novelist:
  • 121 Answers
My name is ArmyMason, might I suggest trying ccleaner www.ccleaner.com and see if that resolves the issue. CCleaner cleans out registry and could resolve some issues. Here is a link that shows registry tweeks to help with speed issues also. http://pcs.suite101.com/article.cfm/speed_up_internet_explorer
If this doesnt work might I suggest checking out our premium service and chat live with a tech.
Thanks,
Armymason
Posted on Feb 24, 2009
My acer am1200 is slow
It sounds like you need to do some cleanup, first go into IE explorer tools> internet options click on delete history. Next at the command line run disk defragmenter
Mar 30, 2014 | Acer Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
My N100 notebook is very slow in process
if it is a windows computer, try running defragmenter and disk cleanup.
to run defragmenter, in the search box in the start menu (in vista and windows 7) and search "defragmenter" select the c drive, and defragment it.. while you're at it, set up a weekly defragment with the defragmenter schedule.
To run disk cleanup, search for "disk cleanup" in the same search box. select the c drive, and check all the things you want to clean up.
you can always just do a scan with your antivirus to check if theres a virus slowing your system down.
Oct 07, 2012 | Samsung N150 (36725723009) Netbook
My computer is running slow.
Many factors may cause your Windows 7 running slow: lack of memory, useless programs, wrong startup settings, junk files, registry redundancies, viruses or spyware and more.
If you computer is running slow or starting up slow, you may visit this article to learn more.
Jan 09, 2011 | Computers & Internet
Have an ACER netbook. It was running very slowly. Was told that there is zero space left on the hard drive and that a system restore is required. Would you please tell me how to do this? Thanks
I recommend you have a quick look in your documents, music & pictures folders and clean out unused/unwanted files first.
System restore is a great tool but not usually the right tool to use to free up hdd space :)
If your running on Windows I also suggest running the Disk Cleanup wizard.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Cleanup.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Cleanup.
Once DC has analyzed the PC it will come up with a set of options. It should be safe to select the following and Click OK to continue removing them.
  1. Temporary Internet Files
  2. Recycle Bin
  3. Debug Dump files (WIN 7 / Vista)
  4. Temporary Files
Once you click OK Windows will then remove these files from your HDD freeing up some space. Its always a good idea to run Disk Defragmenter afterwards to ensure optimum performance.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Defragmenter.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Defragmenter.
Select your primary O/S drive (usually C:) from the list and Click Defragment. Wait for the Defragementer to complete (It might take some time :) ) then restart the PC.
Hope this helps
BD
Sep 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
Why are my pc to slow and how can i find a good virusprogram>?
Speed depends on:
* the disk-drive -- run "Disk Defragmenter" to optimize the placement of files, and run "Disk Cleanup" to delete unnecessary files;
* the CPU-speed (a laptop computer running only on battery power will slow itself down; so, connect the AC power)
* the amount of RAM (add more RAM).
See: http://www.Microsoft.com/security_essentials for free anti-virus software for XP/Vista/7 (not Windows 2000).
May 07, 2010 | Computers & Internet
Computer takes longer to boot up, plus is running very slow
1. To increase PC boot speed:
There must be too many programs automatically start when you boot your PC. To manage them, click Run, type in "msconfig", select "Boot", then you can disable unnecessary programs from that list.
2. To increase PC running speed:
* Adding RAM is the most effective method, but if the RAM is already at the maximum, then do the following.
* Run disk cleanup and defragmenter. But to be honest, the built-in Disk Cleanup and Disk Defragmenter run quite slow and they will take you quite a long time, so I never use them. Third-party programs are better.
* Run registry optimizer software and defrag. No Windows built-in tools to do this. Search on google or refer to this free registry cleaner review.
Jan 11, 2010 | Toshiba Satellite M65-S821 Notebook
Stuck on loading your personal settings it is so slow
try this press ctrl alt delete when loading your personal setting
Jul 10, 2009 | E-Machines eMachines Desktop PC
E-mail
This is a very strange solution, hopefully someone can help you out more than me, though whenever I have problems that are strange especially with microsoft email or anything internet related I delete my temporary internet files and reboot, and the problems go away.
There are two ways to remove the temporary internet files, through internet options or disk cleanup.
Internet Options can be found in Control Panel or in tools in Internet Explorer.
Disk Cleanup can be found by going to the Start Menu, All Programs, Accessories, System Tools, Disk Cleanup.
After doing a disk cleanup it wouldn't hurt to do a defrag on the hard drive. Disk Defragmenter can be found in the same location as Disk Cleanup.
Personally I use the free Mozilla Thunderbird and haven't had any trouble. Of course most workplaces use microsoft products and you have no choice.
Sep 11, 2008 | Dell Dimension 2400 PC Desktop
Microsoft Windows XP Home Edition Logo
294 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
