Question about Epson Stylus C44UX InkJet Printer
Red light constantly on
Hiya
I have just installed a c44 plus, both lights are constantly on, if I press the red light it just moves the cartridges - both cartridges are brand new, and I am at a loss what to do
  • miss_summers Feb 24, 2009
    Now it just flashes!! HELP!
    Scholar:
  • 135 Answers
First, disconnect your printer from the power supply socket(not your pc) then after a few minutes, reconnect and see if the printer has reset and back to normal.
Should this fail, uninstall and then reinstall your printer.
Please send feedback if this works thank you.
Posted on Feb 24, 2009
Green light and red light constant
One or both cartridges is damaged. Open the back you and press the red button for about 3 secs then release it. The cartridges will come out and the damaged one is replaced.
Apr 26, 2013 | Epson Stylus C46 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
How do I make the cartridge move to change position on Epson C44 Plus
To replace an ink cartridge using the maintenance button, follow these steps. Turn the printer on, the power light should be on and not flashing.
Open the printer cover. Press the maintenance button (ink-drop symbol). The print head moves to the black ink cartridge replacement position first. Press the maintenance button again to switch to the color cartridge replacement position.
The on-line user guide can be found here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=FGQ8MBMpKlvPPGPcU002FJ8CcV1DwZfroADi&tc=5
Please take a moment to rate this solution, thanks.
Apr 17, 2009 | Office Equipment & Supplies
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson c44
If the green light and the red light is on (neither of them blinking), this means either you have an empty or faulty ink cartridge, or you have a paper jam. Replace both cartridges; is the problem solved? If not, make sure there are no shreds of paper jammed in the paper feed path anywhere. No? Then you need to get a technician to look at it. However, if you want to try dismantling the printer yourself to see if you can find the reason for the jam, report back and I can provide further information.
Nov 09, 2008 | Epson Stylus C44UX InkJet Printer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Epson Stylus C44UX InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
