THE COLD WATER DOES NOT SHUT OFF WHEN FULL
WHEN THE WASHER FILLS UP THE COLD WATER DOES NOT SHUT OFF, THE WASHER STARTS ITS CYCLE BUT THE COLD WATER DOES NOT STOP. THIS WASHER IS PRETTY OLD BUT THAT IS THE ONLY THING WRONG WITH IT.
  • 52 Answers
It sounds like the water inlet valve needs to be replaced. The solenoid which opens and closes allowing water to flow or not flow, seems like it's stuck open. What brand washer? & Model? I could help you find the correct part. They aren't usually too expensive & if you love your washer, it's not worth buying a new one. :-)
Posted on Feb 24, 2009
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Dec 31, 2008 | Washing Machines
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
