Question about Intel DX48BT2 Motherboard - X48, Socket 775, ATX, Audio, PCI Express 2.0, Gigabit LAN, USB 2.0
Ati radeon hd3800 conflicts with ram
Hi there. im running windows vista ultimate 64bit. i have eight gigabytes of corsair ram on my intel dx48bt2 mobo and a qx9770 cpu. the graphics is a ati radeon hd3800. microsoft ran a diagnostics on my system running it buy remote and the test came back that the ati card was the problem and that it was conflicting with the ram. before i got in touch with microsoft i took out 4gig of ram and the system booted up very fast, but as soon as i put in the other four gig (total 8 gig) the system boots like a slug. i did swap the ram about to make sure that it was`nt the ram and that was fine. intel have bench tested the board and all the ports and everything on the board was fine they also tested the cpu and that was fine. i have flashed the bios and done all of the bios updates. all the components have been updated. please please help im at my wits end!! many thanks in advance. D
  • 2 more comments
  • redhaymann Feb 25, 2009
    hi all. the ram im using is ddr3 1333mhz 9-9-9-24 1.6v
  • Chuck May 11, 2010
    as i said before you will have problems running all 4 sticks at rated speed that is why the Nehalem processor came out with triple channel and put the whole memory controller inside the actual CPU. you must slow the memory down manually in bios to ddr800 speed and you might be able to stay at the 9,9,9,24 settings. try this as well as bumping up the voltage on front side bus (FSB). if i were u i would just stay with 2 sticks of ram.
    most likely filling up all slots and all that memory is probably bottlenecking your system. You will probably be faster just leaving two sticks in there. Or if you really need the four try to up the voltage on them and relax timings. so if your timings state on the modules like 7-7-7-21 try to go to 9,9,9,24 and see how that helps. also might want to bump up the voltage on fsb as well.
  • Bob
    Bob May 11, 2010
    By chance are you using 1600 MHz memory? What are the memory specs?
    Problem Solver:
  • 4 Answers
Just a shot in the dark here maybe you're power supply needs a little more power to support that video card + 8 gigs of ram + all other peripherals you use
Posted on Mar 11, 2009
For
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from www.playtool.com. I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
www.american-media.com
Pentium 4 3.06Ghz
1G RAM
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum http://www.techsupportforum.com/forums/f24/adding-ati-radeon-9600pro-agp-slot-issue-128485.html#ixzz1FKivifx5
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
I cann't play fifa 11
you need a graphic card - I have geforce 9600
Feb 24, 2011 | Computers & Internet
E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
Feb 03, 2011 | Computers & Internet
Will fifa 11 work on ati hd 4750??
Minimum System Requirements for Fifa 11: Operating System : Microsoft Windows XP / Windows Vista / Windows 7
Processor : Intel Core 2 Duo at 1.8 GHz / Athlon 64 X2 Dual Core 5400+
Video Card : 256 MB VRAM - (NVIDIA GeForce 6800 or better / ATI Radeon X1600 or better) **
Memory : 1 GB RAM (2 GB required for Windows Vista / Windows 7)
Hard Disk : 6.5 GB of free Hard Drive space
Sound Card: DirectX 9.0c Compatible
Direct X : 9.0c
Controls : Keyboard & Mouse
Installation : DVD-ROM Drive
**Supported Chipsets :
NVIDIA GeForce® 6xxx series (6800 or greater)
NVIDIA GeForce® 7xxx series
NVIDIA GeForce® 8xxx series
NVIDIA GeForce® 9xxx series
NVIDIA GeForce® GTX 2xx series
ATI Radeon™ X1600 (X1600 or greater)
ATI Radeon™ X1800
ATI Radeon™ X1900
ATI Radeon™ X1950
ATI Radeon™ HD 2xxx series
ATI Radeon™ HD 3xxx series
ATI Radeon™ HD 4xxx series
Yes, it will work on an ATI HD4750.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | EA Sports Video Game Consoles & Games
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Jul 05, 2009 | Dell RADEON X600, (128 MB) Graphic Card
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ECS 915-A(1.1) Ram Reading Issues
Is it a single ram module or dual ie. 2x 1gig ddr2 533?
What motherboard are you running?
Is it possible that you've given a static charge out while handling the ram?
Feb 27, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Feb 29, 2008 | ASUS P5RD1-VM Motherboard
Intel DX48BT2 Motherboard - X48, Socket 775, ATX, Audio, PCI Express 2.0, Gigabit LAN, USB 2.0 Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
