Question about Canon PIXMA MP130 All-In-One InkJet Printer
"the waste ink absorber is almost full"
My Canon Pixma MP130/110 alarms:
"the waste ink absorber is almost full" how to fix it. There was no instructions in the manual.
  • melodyariel Feb 27, 2009
    is this the part which holds the ink how do i get into the pad?
    President:
  • 623 Answers
Although the instructions posted here are for a different model, the procedure is almost the same for all ink printers. (I used it to fix my HP printer.)
Even if you can't get the ink pads out, you can try to dry them with paper towels.
Important: DO WEAR GLOVES!!! Put plastic bags around your work space. The ink IS evil and will not come off of anything it gets on.
The first time I did it without and it took forever to get my hands clean again.
Posted on Feb 24, 2009
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
I hope this help!
Posted on Jan 15, 2015
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Waste ink absorber full
Hi There you can try
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
437 people viewed this question
old marine
old marine
