Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
Samsung SyncMaster 912N Monitor Stops Working Right and Displays "Not Optimum Mode..." - Resetting mode does not fix. Any help is appreciated.
Did you ever get this resolved? If so, how? I'm having exactly the same issue. Thanx.
Posted on Dec 09, 2009
What is causing not optimum mode. 1280 x 1024? Message. I cannot get past this message. Help please!!!
Have you installed your graphics driver? If you have try change the resolution to the maximum possible which is 1280x1024 for your particular monitor.
Aug 19, 2014 | Samsung SyncMaster 912N 19" Flat Panel LCD...
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
Jun 05, 2011 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Not optimum mode
This means that your resolution (the amount of pixels) is not the same as your monitor's recommended setting.
The easiest way to fix this is to go into your display settings (right click your desktop and, if XP: Properties->Settings or if Vista/7: Screen Resolution) and drag the slider all the way to the right (XP) or top (Vista/7).
If the highest setting makes your screen go blank for more than 5 seconds, press Esc and try the next setting down. Do this until your monitor correctly displays the highest setting allowed.
Mar 27, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
NOT OPTIMUM MODE
Solder a 50 ohm precision resistor between pins 5 and 6 of the Novatek NT68F63LG
I had this same problem on 3 Samsung 710N displays and this fixed the problem.
I have read others have also been successful but the value of theresistor was slightly different in some cases. I would start with 50ohms as that seems to be a common value fixing most displays.
Here is the reference URL to the ORIGINAL person that solved the problem.
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
Jan 28, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
516 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
