Question about Panasonic PV-DV953 Mini DV Digital Camcorder
Panasonic pv-dv953 power doesnt stay on
Power light flickers when AC adapter or charged battery is mounted then shuts down.
  • 3130 Answers
SOURCE: panasonic PV-L557D vhs-c camcorder wont stay on
it probably goes into a shutdown mode because of those dreaded pan capacitors!!. These are small surface mounted capacitors that dont just go bad in almost all camcorders but they will leak and be very very corrosive to the Printed curcuit board and eat up the pc traces!! The onlt way to see if this is the problem is to have the unit looked at by a quilifyed camcorder specialist and see if that is the problem? Good luck
Posted on May 11, 2006
SOURCE: PV-L606D Camcorder Battery Charger and Car adapter
I have a friend who has one, and has not used it for some time. Here is his e-mail
Posted on Oct 14, 2007
  • 373 Answers
SOURCE: Panasonic PV-DV953 video transfer to pc
I think, yes have to work.
Because the RCA in a PC. is for capture AUDIO and VIDEO.
Of any source.
But you have to be sure they are INPUT.
And the respective program to capture video with. RCA inputs in your PC.
I have on my PC.. Video capture program with a security camera System. That work in the same way.
Just with a different program.
OK I hope this help..
Posted on Jul 30, 2008
SOURCE: lost ac power adapter ac cord panasonic sdr-s7 camcorder
Go to Radio Shack, bring your camera, and they will sell you an AC adapter part number: 273-1696 for $30.
Posted on Aug 30, 2009
  • 536 Answers
SOURCE: Panasonic PV-42D Mini vhs-c palmcorder will
Most likely the power circuitry is this ole girl has bit the dust.
The same thing happened to my PV-42 6 years ago.
You've done very well getting 17 years of service from her.
Time to put her on the memorial shelf.
Posted on Dec 21, 2010
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system is a common problem with laptops,
Problem symptoms:
here is how to repair:
Nov 26, 2010 | HP Compaq Evo n610c Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
My internal battery will not charge
90% of the time the battery is bad. No quick fix, other than test the battery or replace.
please rate
Mar 26, 2009 | Accurian 16-454 Television
Acer laptop shut of during power outage .
From the Acer website:
Power Issues or Will not Boot
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Problems with charging
This still could be either if the cord is being moved at the same time. when the laptop is able to turn on, Does everything (programs, software, etc) function properly? If yes, then we can narrow it to the battery or ac adapter.
To find out whether it is the ac adapter or battery, take out the battery, and see if the laptop powers up and stay that way. If it intermittently closes or shuts down, it's most likely the ac adapter.
If it stays powered on, even if you move it, then it's most likely a battery issue.
If you want to be sure before spending some money, go to a friend's, neighbor's or computer store with a with the same manufacturer (dell, toshiba, etc), and borrow their ac adapter to check
Nov 21, 2008 | Computers & Internet
Mpeg recording to SD card
This may have something to do with the fact that the camera powers down before the battery is exhausted as the maximum run time is 140 mins which is roughly the time you say it stays on for.
Oct 05, 2007 | Panasonic PV-DV953 Mini DV Digital...
Panasonic camcorder
CCD sensor faulty and has to be replaced. A properly manufactured CCD transduced should last +-15 years so you should isist on having it repaired free of charge by Panasonic agent. ( worst case pay for labor but not the faulty component : 1 hour labour with this problem ).
Aug 29, 2007 | Panasonic PV-DV953 Mini DV Digital...
Panasonic PV-DV953 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
