Question about Canon imageCLASS D880 All-In-One Laser Printer
Wont turn on
My Canon image has no power and the credit card mach bext to it works fine. They are plugged into the same outlet, but my copier is dead in the water. No power, we may have had a power serge I don't really know, it was working fine then just went dead. whats wrong with it?
Is it plugged into the top plug that is controlled by a wall switch?
Posted on Apr 30, 2009
Canon printer wont start after power outage
Confirm that the printer is still plugged into a working power outlet
try plugging this printer into a known verifiable working power outlet and then try powering it on
if it still doesn't power on I hate to say this but it would cost you more to get it repaired then for you to purchase new the current replacement model for the mx882 is the mx922(Amazon @ $99.00)
Mar 04, 2014 | Canon PIXMA MX882 Wireless All-in-One...
The power wont turn on
check first the power cable if properly connected to the back (or side) of the machine and on the power outlet. if its plugged in to a power extension, unplug it from the machine and from the power outlet, leave it like that for 2mins, and plug it back to the machine then directly to the wall outlet instead. if theres still no power, press down and hold the power button for 30secs, if nothing happens, the machine is dead, if its still under warranty, bring it to the store for free service.
Apr 06, 2011 | Canon PIXMA iP1300 Printer
There is an amber light on the right hand side of the top and it wont turn on. Is my pixma dead?
hello
try to check your power outlet then check your printer cable or the power port of your printer is disconnected inside.
do this: remove the power cable from the plug outlet and from your printer take ten minutes and plug it again.
thank you
Mar 05, 2011 | Canon PIXMA MP970 InkJet Printer
Rjwylie@wowway.com..... I asked for assistance regarding fixing my pixma 600 printer. I mentioned that I checked the outlet and the power cord {with a meter}. They are O.K. Do you have any other...
It appears that your MP600 Power supply has died.
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Feb 11, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP810 wont turn on.... HELP!!
The only thing is to open it and get to the power board, check the fuse on the board. if it's ok then you need to change the board
Jun 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Printer suddenly dead
It's possible the power supply died, however, there is a 3amp fuse on the slide in power unit that could have blown. I would check it before taking it to the recycling pile. If you mess with it be careful around capacitors, they'll hold a charge even if not connect to power for several days.
Nov 24, 2006 | Canon BubbleJet i560 InkJet Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
85 people viewed this question
old marine
old marine
