Question about Dell 924 All-in-One InkJet Printer
Paper jam I have a Dell All-in -One Printer 924...I have had it for only one year and have never got to use it much because of the paper jam...I put the paper in and it goes in on one side but on the other side gets jammed and printer says load paper...and it will not go through or print anything there any way to solve this problem?
  • 514 Answers
I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if you can't see anything, then take a letter sized piece of poster board and try to run it through, that should clear any foreign debris (such as paper clips that you may not be able to see) good luck!
Posted on Feb 28, 2009
Displaying paper jam fault, no paper jammed in printer
put out buffer memory and restart printer then put buffer again it works
Dec 17, 2009 | Dell 924 All-in-One InkJet Printer
Non-existent paper jam
There is almost certainly an optical sensor somewhere that either has a tiny bit of paper or dust in it. Try blowing dust out of the insides of the printer with a shop vac set to blow air out. Also try disconnecting/reconnecting the optical sensors throughout the paper path of the printer. Only do these things with the printer disconnected from everything.
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam in printer
go here for the manual ("") good luck!
Feb 24, 2009 | Dell 924 All-in-One InkJet Printer
PAPER JAM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Since when the printer not picking up paper from tray or sheet feeder.
Check if the Cover are firmly closed, also look out for any piece of paper jammed the printer.
If it is ok, then check to move the carriage of cartridge/roller and clean it out if you can.
The spring of tray attached on both side may be need to check.
Let me know if I can assist you further.
Oct 01, 2008 | Dell 924 All-in-One InkJet Printer
924 printer paper jam
below the opening part to take a copy you open it, the cartridges will move to a side automatically. There you will be able to see the paper.
May 03, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Trouble Loading Paper
Make sure the printer is not jammed. Mine was jammed last week and I couldnt tell because it was a very small piece of paper. Once I figured that out everything worked fine.
Jan 22, 2008 | Dell 924 All-in-One InkJet Printer
Dell photo 924 all in one printer paper promblem
Unplug the power adapter from the printer and then remove the papers from the printer , open the printer cover and look for any obstructions , lift the printer and shake it firmly, turn the printer upside down and gently tab on it , roll the paper tray rollers manually , put back the power adapter and then try printing a document with only one paper in the paper tray if it still gives the same error then its an issue with the printer and if the printer is under warranty then get the printer replaced .. or purchase a new printer instead of getting it repaired .. dell is offering a new printer 926 for $49 with 1 year warranty.
Do lemme know if that helps.
Jan 19, 2008 | Dell 924 All-in-One InkJet Printer
Reading "paper Jam" but no jam-no paper to be found?
dell all-in-one 924 keeps giving message to clear paper jam. There is no paper in the printer HELP!!!!!
Oct 23, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
54 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
