Question about Mitsubishi VS-50607 50" Rear Projection Television
Picture bowed up from bottom/black bowed bar.
In addition, the picture occasionally pulsates...not a flicker, but a definite pulsation.
    Problem Solver:
  • 4 Answers
I was able to find this solution extremely helpful from Troylove11. It fixed my problem. troylove11
Rank:Picture bowed up from bottom/black bowed bar. - wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Mar 14, 2009
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Hitachi SF-65PX Washing Machine
Hi just read your posting.As I understand from your posting, the center spline on your pulsator is stripped and you would like to replace only the center spline instead of the whole pulsator.Is this correct?Are you in Australia?If so then reply back and I can give you some contact details on where to obtain a pulsator from.I dont think you can buy just the center piece only the whole pusator.There are places that sell the pulsators secondhand which will save you some money.Please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Jul 24, 2010 | Washing Machines
Picture "pulsates", becomes small and fuzzy
Ur convergence is dead.Need to buy the convergence kit use it parts.U know how to solder right?Tries these websites Ebay.com,Tv Repair World.com,or Shopjimmy.com.
Sep 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi ws 65857 no picture but screen pulsates. bulbs ok
code 12 indicates no fault. tv probably needs the high voltage board rebuilt, have a shop do it. Maybe you need to check all the connections.
Aug 30, 2009 | Televison & Video
My tv goes blank with sound only.
tough call. from your decription it could be the tubes the pulsating. but if i had it in the shop i wwould first look at the convergence curcuit. the fact that the on screen display come up in colors inidcates convergence problems. you might have multiple component falure there. as for cost it could be diddicult to say. average repairs like this barring piture tube problem at my shop run 200 labor and about 150 parts. this is just for convergence cuircit rpair
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Pulsating screen.
Due to the flourescent lights that are used in this product, i would suggest trying to return the product for a new one, as one or maybe a few of the bulbs may have busted or become loose due to the impact caused by the fall.
Apr 14, 2009 | Envision EN7410 17" LCD Monitor
Green Hue with Pulsating Picture
replace C933 = 1000uf a 16v
Jan 09, 2009 | JVC AV-27D305 27" TV
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
