Question about Welding Tools
Campbell hausfeld wg 3060wire feed welder as soon as you turn it on the wire starts feeding . the switch is ok. any suggestions?
    Champion:
  • 225 Answers
Stuck relay for feed motor.
Posted on Jul 05, 2009
110 volt welder the wire stays energized even when the feeder stops and your off the trigger. Campbell Hausfeld flux 80. Any ideas?
That could be 2 things. Either the switch in feed assembly is bad or the relay inside the unit is sticking.
Nov 16, 2015 | Campbell Hausfeld Welding Tools
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
The gun on my welder is broken and need to fine a new one the wire feedes thru gun to weld it is a cambell hausfeld mig welder
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
Mar 02, 2010 | Campbell Hausfeld MIG / Flux Core Wire...
Campbell Hausfield wire welder feeds after trigger release!
has it done this before some wire feed welders the cheaper ones have hot switches mean that push wire all the time stuped i know but if it is not a hot switch than it is making contact some how and it could be inside the wip check it as best you can or take the wip in to where you got it from
Nov 10, 2009 | Cars & Trucks
Wire won't feed
If the feed motor is not turning, then you'll need to have the unit tested by a repairman to find out why it isn't turning
Oct 06, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Feb 22, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
88 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
