Question about Jensen VM9510 Car DVD Player
INSTALLING A DUAL XDVD710 TO A WIRE ADAPTER TO PLUG INTO MY
I HAVE A DUAL XDVD710 AND I WANT TO INSTALL IT MY SELF. MY CAR IS A 1995 FOR CROWN VICTORIA LX, IT HAS THE FACTORY PLUG FOR MY RADIO, I HAVE THE ADAPTER FOR A AFTER MARKET RADIO AND ALL WIRE COLORS MATCH ON THE XDVD710 AND THE CAR ADAPTER. MY QUESTION IS WILL IT WORK JUST THE SAME IF I MATCH MY DUAL XDVD710 WIRES TO THE ADAPTER AND JUST PLUG IT IN THE FACTORY CAR HARNESS, THE E-BRAKE IS THE ONLY THING THAT DOSE NOT MATCH A WIRE SO I GUESS IMA HAVE TO DO THE GROUNDING TRICK...I NEED A REMOTE ALSO......ANYBODY KNOW WHERE TO GET ONE?
MakikiChris
  • 84 Answers
SOURCE: no hook up guide
Please update your post with the Serial Number of your Player and I will be able to help you.
Posted on Jul 31, 2007
simplemitch
  • 752 Answers
SOURCE: Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Posted on Sep 20, 2007
Benimur
  • 6966 Answers
SOURCE: jensen uv8 wiring issues
The wires you posted need not go anywhere not unless you have a device that will attached to them.
antenna power - connects to the motor of a telescopic external car antenna. When you power on the unit, it will automatically raise the antenna;
amp power - connects to an add-on/external amplifier. This switches/triggers the amp to gon when the Jensen is powered up;
reverse - attaches to the reverse light of your vehicle. This will tell your unit that you are reversing and will activate a rear view camera.
As earlier stated, if you do not have any use of these devices then there is no need to connect the above described wires to anything. Connecting them to the ground would have a bad effect on the internal circuitry of the Jensen since they are meant to supply power and therefore are connected to the B+supply when the Jensen is powered except for the reverse which would sense a 12V from the vehicle's transmission. Connecting them to the constant B+12 would have no ill effect except that your Jensen would always be on.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Posted on Nov 20, 2007
SOURCE: what wire goes to what
1) Like munstar said, you need to get the harness from any car-audio retailer. Once you get that, you'll be able to just match up the colors.
2) The wiring diagram is in the User's Guide. In there it lables what each wire connects to.
Posted on Apr 24, 2008
SOURCE: Need to replace the main wiring "harness" that connects all electrical components
http://www.hifiaudioonline.com/inc/sdetail/5538
Posted on May 24, 2008
Installing a jvc cd player into a 99 crown vic
the best thing to do is not to cut factory wires and buy a wire harness from walmart or miejer and the wires will be color coted match up and tape them up them plug the two harness's together that is the best way to wire up a aftermarket radio
Sep 24, 2012 | JVC USB/CD Receiver with Dual AUX Input...
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
It will not load cd or dvd it keeps coming up
The loading mech or poss. the read portion of the disc player is out of whac. In other words the cd dvd portion of your deck is defective and short of having it repaired by a techinition there isnt much you can do. Its a **** shoot but you may be able to unplug the unit let it set for a few minutes and plug it back in may rest the mech., but like I say its a **** shoot. Sounds like its time for a new deck or a trip to the repair center.
Jul 30, 2010 | Dual Electronics XDVD710 Car DVD Player
Dual xdvd710 whats the white/brown reverse lamp wire for
It is if you want to install reverse back-up camera to your rear bumper. You do not need to connect unless you have a reverse back-up camera.
Aug 08, 2009 | Dual XDVD270 Car DVD Player
Dual xdvd710
check on the main wiring harness you wil see a black box on the yellow wire. open up the cover. there is a 10 amp mini fuse inside. if it is blown replace the fuse. also check your main radio and accesssory fuses in your fuse box. if no fuses are blown check all wiring connections.
Jan 31, 2009 | Dual XDVD8181 Car Video Player
Dual xdvd710 wire code
http://www.yotatech.com/~corey/tech/slc_stereo/16.jpg
its a sony diagram but the codes are the same, now you should have an extra solo green i belive may be a diffrent color that is supposto go to the parking switch, just hook this up to a ground
Jul 25, 2008 | Car Audio & Video
Dual XDVD710
I need to reset the password from my XDVD710. So I need your help.
THX
Apr 03, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd710
If you can find a separate tv tuner with remote the run it through the unit rear input. But stand alone tuner is rare if it even exist. Search Ebay to see if you can find one. There is another way by hook up a small portable tv with video/audio output and use an adapter from RadioShack to send the signal to rear input of the unit, but picture and sound quality is only as good as the reception of the tv. Goodluck.
Feb 10, 2008 | Dual XDVD8181 Car Video Player
Dual xdvd710
find the memory wire [yellow] and make sure you connect it right if that isnt the problem check fuse box or make sure your remote is not hooked there
Nov 13, 2007 | Dual XDVD8181 Car Video Player
Jensen VM9510 Car DVD Player Logo
410 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
