Question about HP Pavilion dv1000 Notebook
My dv1000 does not switch on, no charging light, voltage on battery ok, where is the voltage regulator pq 118 located ? regards Thormundur, email: flugradio@simnet.is
  • J314 Mar 02, 2009
    I tried discharging the system with the battery and power disconnected. The system will not turn on and shows no lights. I was using it and there was a pop and it was dead.
  • 531 Answers
Try DC connector, then shorted caps(common problem), then resolder "max1999"
Posted on Mar 19, 2009
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
Aug 16, 2015 | 2001 Ford Expedition
How do I check regulator on s2048 scotts mower
The charging light (as you call it) might not be a problem at all; and I question whether or not there is any adjustable regulator. Now the fact that the voltage light comes on seems to indicated that it is working properly: as the PTO and/or lights add load, the light comes on to indicated that battery reserve is taking up the the slack until battery charge builds back up to where it is resisting further voltage input. Sometimes it is just a matter of continuing until the light goes out. Occasionally, I find that switching the engine run switch on and off momentarily will reset and extinquish the voltage indicator light. Remember also that battery reserive might have drained in storage so had not built up if lights or mower are switched/started soon after initial engine startup. Finally, too frequent charging of battery could be sign of diminishing battery capacity or increasing battery internal resistance. All said, though, I would be more concerned by the voltage light's coming on without associated sudden load increases.
Nov 05, 2014 | Garden
The battery light is on and the battery is not being charged. The voltage regulator is located in the computer where is the computer located
The computer is behind the bumper under the air filter box. You will need to remove the air filter enclosure to access it.
Jul 16, 2012 | Cars & Trucks
I have a 1984 dodge D150, not charging, battery is good,charges with charger\r\ntruck starts and runs pretty good,but is running off of battery, NEW altenater,regulator,and belts belts are tight,replaced...
The first thing you need to do is stop wasting your money by replacing parts. Then get a volt-ohm meter and a test light to test the circuits between the battery, the alternator, the ignition switch, the starter relay and the voltage regulator. (a.k.a. Charging System Circuits)
To start, the "B+" or "BATT" terminal on the alternator (large black wire) MUST have a solid, direct connection to the battery. Check for the proper voltage here. Then, the red wire on the alternator at the "F2" terminal should be HOT at all times. If not, you probably still have a bad fuse link that you missed. The "F1" terminal on the alternator (Light Green wire) is known as your "FIELD" wire. It comes from the "IG" terminal at the voltage regulator. It should be hot any time the key is in the ON position. If not, your voltage regulator is not working or your ignition switch is not providing power to the regulator. Finally, The "F" terminal (Red wire) at the regulator should be hot any time the ignition switch is in the ON position. This actually gets it's power from the starter relay, which gets its power from the ignition switch.
Please also review these articles:
What Else Could Be Wrong?
My Car Won't Turn Over
Jun 12, 2011 | Dodge Ram 150 Cars & Trucks
Battery light comes on. Had battery tested and it's OK.Checked battery voltage with key off 12.04 volts, started it voltage is 14.45. The light comes on after driving for awhile.
OK, sounds like a bad voltage regulator or loose belt. But, it's more likely a voltage regulator on the alternator that is not supplying enough voltage to the battery over time.
For maximum peace of mind, I would have the alternator replaced if you experience any starting problems attributable to a weak or undercharged battery.
14.45 volts doesn't sound bad to me, for an initial voltage, but there may be a problem with the alternator (like a bad diode trio) , which controls the battery charge light pretty directly.
Oct 28, 2010 | 2000 Ford Expedition
1991 ford festiva replaced alternator new
it is part of the alternator actually on a lucas unit, a small black box bolted to the rear of the alternator.
You may have a faulty ignition switch or a corroded engine earth cable causing the alternator not to reach charging voltage.
Jan 13, 2010 | 1991 Ford Festiva
Recently having problems with my 2000 Fatty not holding charge. What should stator be putting out on voltage meter? Voltage meter climbs as rpms go up, I would presume that this indicates stator ok? Bike...
First, take your battery somewhere and have it load tested. Fat Boys are tough on batteries as the battery sits in the "horseshoe" oil tank and is subjected to high temperatures due to the hot oil in the tank. Battery life is typically two years although I've seen some go longer and some not last that long. Have the battery tested before you start spending money.
To check the stator, you unplug the regulator at the engine case. Down inside the plug you'll see some electrical connectors. Connect a DVOM (digital volt ohm meter) to these connectors (one lead to eac pin) and put the meter in the 50 volt or higher range AC voltage. This is important that your meter be set to measure AC voltage because at this point, the voltage is indeed an Alternating Current voltage coming out of your alternator. Start the engine and bring it to a high idle. You should be reading over 20 volts AC. The book says that you should read 12-18 volts per 1000 engine RPM. If your engine is turning 2000 rpm, your meter should read 24-36 volts AC.
To test the regulator, first charge your battery to a full charge. Then connect your DVOM across the battery, red to positive, black to negative. Put the meter in the 20 volt DC range. Start the bike and bring it to a high idle. The voltage will start at somewhere around 12.5 volts and climb to about 14.5-15 volts. This would indicate that the regulator MAY be alright.
Now, have you changed any of the lights on your Fat Boy? I've seen people change and add lights to the point where their alternator could no longer put out the current necessary to handle the load. If this is the case, you may need a higher out charging system.
I don't know where you're located but $260 seems quite high for a voltage regulator.
Dec 30, 2009 | 2000 Harley Davidson FLSTF Fat boy
My battery light on my dash does not come on and my car won't start. I change the Alternater,Battery, and Starter. Where is the fuse that control the voltage regulater located.
That has nothing to do with the voltage regulator. You need to check the WIRE from the ignition switch to charge indicator light. Seems like you may have an open circuit there. Get the wiring diagram for your charging system and check it out.
Sep 15, 2009 | 1996 Nissan Maxima
Battery Light on and the Battery is fine but will not keep charge
RECHECK the New Alternator This is Not Unheard of as I Have Experienced it Myself Several times.
After RULING it out and the Fallowing,Main relay box Power terminals, Corroded Loose fit nuts Etc.
Consider Voltage Regulator, Read the fallowing "CAREFULLY"
CIRCUIT OPERATION
The Electronic Voltage Regulator (EVR) is not a separate component. It is actually a Voltage regulating circuit located within the Powertrain Control Module (PCM) . The EVR is not serviced separately. If replacement is necessary, the PCM must be replaced.
Operation: The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground.
Voltage is regulated by cycling the ground path to control the strength of the rotor magnetic field. The EVR circuitry monitors system line Voltage and battery temperature (refer to Battery Temperature Sensor for more information). It then compensates and regulates generator current output accordingly. Also see Charging System Operation for additional information.
FOR Detailed Diagrams,on Entire Charging system they Must be Emailed,as they are too Large for the Formatting that "FixYA" uses my Email add. is My nickname here but add @aol.com By all Means If this is of Help to you , Then PLEASE RATS Me Thank you and have a Blessed DAY rejakwilson
Jan 21, 2009 | 1997 Dodge Caravan
Battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Mar 22, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
236 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
