Question about Home
110v 2 HP Waterway Spa pump sometimes does not start
My new last year 2 HP Waterway spa pump has only sometimes started  correctly. It often stays stalled with a moderately loud buzz or hum.
This has been true from date of purchase. It can be started by rotating the shaft once or more times and retrying.
I have been using the pump somewhat satisfactorily by programming the Balboa  VS 500 controller (which was installed new at the time) to continuous circulation. It switches perfectly between high and low speeds with the topside control button.
If the contact mechanism in the 2 horse is similar to that in a 1 1/2 HP I would presume this symptom could be caused by a very slight misalignment in the part in the switch when it occasionally stops at a spot in the 360 degrees of rotation that does not allow the switch to close properly.
I do not know if the switch in the 2 HP (110v) is similar to that in the 1 1/2 HP. I believe access is somewhat different. Not a lot of fun to get at pump!
The above ''suspicion'' was not thought of by me before a conversation that I had with Waterway.
They would accept the return of the pump in warranty.
It would almost seem to me with high shipping costs that I could get a local electric motor repairman to shift the switch a bit and I would have shorter down time.
I suffer from Myofascial Pain Syndrome and do not like to be without access to the spa to moderate the considerable pains when this is bothering me.
Any help appreciated.
harold Smage
  • 125 Answers
Usually is a dead spot on the motor. a local motor shop can look into that however if it is under Waterway warranty I would pay the cost to get a new motor from them. These are expensive.
Posted on Feb 24, 2009
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Pump acts like it is froze up. It hums and smells like it is burning when it runs. It hums then shuts off, hums then shuts off?
Either you need a new start/run capacitor or the bearings have seized. If it's been running loudly recently, the bearings have probably seized. If not, the start capacitor is probably bad. This can sometimes happen when the motor windings start to develop a short. If you replace the capacitor and it blows again, you'll probably need a new motor.
Oct 22, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
How do you remove the impeller from a Waterway Executive 48 spa pump
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Oct 07, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Jul 05, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Electrical connection to pump
can you photograph the new connections for me? if you look at the connections, the neutral normally has a solid link across it, the earth will be to the frame and the other two are the high and low speed live connections.
Mar 14, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Home Logo
243 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
