Question about ASUS N50Vn Notebook
The built in camera doesn't work. It displays black screen.
I use ASUS N50Vn PC Notebook since 3 months. The system always started with SmartLogon service, it's very comfortable and useful way to log on to the user account. The camera window has become black several days ago without any apparent reason. I didn't install any program or device. I tried to turn camera off, uninstall driver, I booted system several times but I couldn't make the camera back to work. So, before I'll send the laptop to the service, I have to be convinced it's hardware problem not the software one. I should be very grateful for your help in solving my problem.
Best regards
Jacek
  • jacek82 Feb 24, 2009
    Thanks for help ArmyMason, I tried to restore the system without any success, so you must be right- only service can help.
    Best regards
    Jacek
    Novelist:
  • 121 Answers
Hey Jacek,
I think its a hardware issue too, If you haven't installed anything I don't see why this would be. Is their any configuration software for the camera that allows you to adjust the color? I would check that out first, you could also try and using the system restore function. Go back to the day you bought the system and see if that resolves the issue. If that doesn't work it has to be hardware related.
Goodluck,
ArmyMason
Posted on Feb 24, 2009
How to open bluetooth
on the taskbar on the right bottom corner of the screen it will show apps open in the background, click on the arrow to show more, then click on bluetooth
Apr 17, 2014 | ASUS N50Vn-C3S 15.4-Inch Notebook PC
Asus laptop manuel
This is also in respect to your previous problem stated;
http://www.fixya.com/support/t12161144-screen_cover_off
It is also in regards to an Asus N50Vn series of Netbook PC.
A) Remove ALL power. Remove the AC adapter (Charger) and Battery.
If memory serves;
B) There are 6 synthetic rubber screw covers.
4 across the top, 2 on the bottom in the corners.
I use a computer pick, and gently pry them off. (Lift up on one side) They have a type of rubber cement on them, and if careful, can be reused.
Place them on a clean surface.
(Yes. They like to stick to the tool, and your fingers)
Underneath the 6 screw covers are 6 Philips head screws.
Remove them.
(Note*
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
Do Not mix them up)
The thin plastic frame in front of the LCD screen is the LCD Bezel.
Resembles a picture frame.
Remove it.
The outside edges of the Bezel have plastic tabs. These mate with plastic latches in the inside edges, of the Display Cover.
This video will help with the Display Bezel removal,
http://www.youtube.com/watch?v=o7vSFvHphxM
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) can be a CCFL, or a series of LED's.
From what I gather the Asus N50VN series uses LED's.
I don't have the exact model number to see if a screen Inverter is offered, or it is included in the purchase of the replacement LCD screen.
(To me, would indicate the screen Inverter is an integral part of the LCD screen assembly, for certain N50VN models )
Regards,
joecoolvette
Mar 25, 2012 | ASUS N50Vn Notebook
Asus smartlogon can be installed on asus vx6 win7 but after reboot sais can only be run on an asus-computer!?! ;(
Are you using the Win 7 operating system which came with the computer when you bought it? If not, you need to use the OEM operating system, intall the utility and the driver to get it work. It is an ASUS utility and only works with OEM which came from ASUS.
Hope this helps.
Jun 02, 2011 | ASUS Eee Lamborghini VX6-PU17-BK PC...
Asus camera not working
Go to start and search for Asus virtual camera. right click asus virtual camera. go to properties. click the compatibility tab. and click the box that says run in 256 colors.
problem solved =)
Mar 20, 2010 | ASUS M51Sn-C1 Notebook
My asus smartlogon keeps crashing and shows critical on my windows 7 reliability monitor daily please how can i fix this ?
uninstall the asus smartlogon program thru add/remove programs. Then go
ahead and go to this page:
http://asus-smartlogon.software.informer.com/
click on the download button. This will download version 1.0.7. Not sure the current version that your running but download this one and install it. If you happen to find a more current version. You can always download that one at a later date.
Jan 06, 2010 | ASUS Computers & Internet
I cannot get the wireless to turn on using the function key. is there some other way to turn it on? my laptop is not a n50vn its n50vc but that model wasnt listed.
There is a physical wireless slide switch at the right of the indication light. It seems that you have to switch it on.
Dec 27, 2009 | ASUS N50Vn Notebook
Asus n50vn combo fn+f2 stopped working.Lan and bluetooth are inoperative.
Hello!  I just posted I had a problem but now I've solved it. User LOSNAD posted the simple solution here.
http://vip.asus.com/forum/view.aspx?id=20090123071339174&board_id=3&model=N50Vn&page=1&SLanguage=en-us
I think we accidentally turned off the wireless switch. The switch is in front of the mousepad, to the left of the mic and headphone jack. OK!
Apr 22, 2009 | ASUS N50Vn Notebook
ASUS N50Vn Notebook Logo
299 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
