Question about Konica Minolta DiALTA Di200 Copier
I'm using a MINOLTA Di200 copier and have no way to adjust the LCD contrast. Is there a way to access that function? My display is too light.
  • 145 Answers
Ther is a sliding botton on the right side of the disply panel that can be adjusted.
good lock
Posted on Feb 28, 2009
How do I adjust contrast?
There are Function Keys to do this.
from Troubleshooting section. Keyboard (if contrast and brightness function key)
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
and Page 10 of the manual
Display Keep your display clean. • Keep your head at a higher level than the top edge of the display so your • eyes point downward when looking at the middle of the display. Adjust the display brightness and/or contrast to a comfortable level for • enhanced text readability and graphics clarity. Eliminate glare and reflections by: • placing your display in such a way that the side faces the window or • any light source minimizing room light by using drapes, shades or blinds • using a task light • changing the display's viewing angle • using a glare-reduction filter • using a display visor, such as a piece of cardboard extended from the • display's top front edge Avoid adjusting your display to an awkward viewing angle. • Avoid looking at bright light sources, such as open windows, for extended • periods of time.
http://www.manualslib.com/manual/205261/Acer-Aspire-3680.html?page=10&term=contrast
Dec 27, 2015 | Acer Aspire 3680 Laptop
Canon fax L250 lcd contrast too light
hello, you can try adjusting the angle of the screen and use the function /menu button to find lcd brightness -- could not find anything in manuel
Aug 13, 2014 | Canon FAX-L250
Printer will not print from any computer
what os are you using a Di200 model maxed out on windows xp at best. what are you using try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Jan 28, 2014 | Konica Minolta DiALTA Di200 Copier
Error cod sc32-04
There is no SC3204 or C3204 code on the Minolta Di200. I would either need the correct code or the correct model of Minolta you have. Please provide better information so I may assist you further.
Thank You for using Fixya.
Oct 28, 2011 | Konica Minolta DiALTA Di200 Copier
Copiadora pitney bowes dl 200 error en dispey co500 lla puse tehrmistor y sigue igual como se resetea este codigo
The problems is in the fusing unit.Clean the thermistor and heater lamp.Reset the trouble:press the microswitch located in the right side to display pane,under the display contrast button.After appair the * simbol on the display,press 3 and the Trouble reset button.
Aug 07, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
C0F32 error displayed in new machine just in 25000 copies
Is the copier is brand new out of the box? If so you have to call a dealer or a good friend that works on them to help you by pass the set-up error code. They put that little curve in to stop none dealer from installing there copiers.. Good Luck......
Jul 29, 2009 | Konica Minolta DiALTA Di200 Copier
I have a Minolta Di351f. It indicates code CO500. This occurred after a power outage last night. What should I do to restore proper operation?Thanks.
Look on the right side of the control panel, just in front of the display contrast slider adjustment, and you will see a small hole. Using a paper clip or similar pointy instrument, press the pushbutton switch in that hole.
The machine will go into warmup mode. When you see a small dot centered on the left side of the touchscreen display, press "3" on the keypad. This will take you to the initial mode screen, where you will see "Trouble Reset" on the touchscreen. Press it.
If the C0500 code comes back in about 60 seconds, it means that you do indeed actually have a problem with the heater lamp not coming on, possibly a blown lamp or thermal fuse.
Dec 10, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
65 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
