Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Canon IR 3570 802 error
I have several users with the same problem. It is intermittent which adds to the confusion. Some send jobs never make it to the recipient. When I check the send log it shows a result NG 802. An 802 indicates a problem with the SMTP server name. This would make since if this was not intermittent. All of my Canons (24 of them) are experiencing this. My HP digital senders are not having any problems. I have verified the SMTP server name, all the TCP/IP settings, DNS, gateway, Max data size to 99. The recipient can receive most of the time but intermitently gets the 802 and sometimes a 995. The e-mail is from the address book so no typo on the e-mail address. This is a large 1300 user community. Any suggestions?
  • 287 Answers
SOURCE: Canon iR C3220 Printer TCP/IP settings
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
Posted on Jul 15, 2008
  • 67 Answers
SOURCE: Canon IRC 2880/3380 Scan to Email client
re install the system software , flash the machine, or clear mmi
Posted on Nov 27, 2008
SOURCE: Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Posted on Jan 15, 2009
  • 118 Answers
SOURCE: canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Posted on Jun 22, 2009
SOURCE: Canon IR C3100n copier "NG 853" error
I too tried the UFRv1.42_Win2k-XP-2003_INF Driver for the Canon C3100 and it worked superbly .
Posted on Mar 31, 2010
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
Hull, my canon IR 2520 cant print when i send the job it only beeps with a red light, can some one help me...
press the status monitor on touch screen. it will show that load paper LTR. that was an error.
go to additional function-> printer settings-> paper size over ride-> make it ON.
Sep 22, 2015 | Canon Office Equipment & Supplies
We have a Canon Image Runner 3235 that is hooked up to a network. Every time we try to send more than one document to print off we get the error message to load paper and it doesn't need any paper. ...
if the message add paper related with specific paper size i.e. add A4 paper in drawer, first you need to check is the paper senzor in drawer set to correct paper size - it is blue circle with markins of paper size. Second thing under printer driver properties on PC check if the correct paper size is choosen.
Hope that helps!
Aug 15, 2011 | Canon iR 2016i Black and White Copier
Is the Duplex facility is available in Canon IR 2016
The Canon IR2016 "I" model has duplex capability aleady built in. The IR 2016 does not but it is available as a seperately purchased add on. It's not hard to put but the instructions (included) is a bit confusing.Once you have succesfully installed the duplex unit you will probably want to put the instructions at the bottom of your bird cage. But an end user should be able to figure it out with patience.The catalog number for the duplex unit is 0418B002AA. And the 0 in the front of this number is important.Good luck and please let "FIXYA" know I helped you. SPINAL
Feb 18, 2011 | Canon iR 2016i Black and White Copier
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Need How-To on calibrating Canon IR-3200...
try under user mode (add.function) cleaning or similar and auto calibration, it will print out 4 test that you need to scann on copier, you just follow the copiers instruction
Sep 14, 2009 | Canon imageRUNNER C3200 Color Printer
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
1,627 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
