Question about Pentax K1000 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
    Scholar:
  • 185 Answers
Mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Posted on Feb 25, 2009
How do you replace the rewind shaft of a pentax k1000 without causing any damage?
Open the camera film cover back.
Stick a flat blade screwdriver between the silver film sprocket, then turn the Film Rewind Crank out.
atdlee@netzero.com
Jun 25, 2014 | Photography
Advance lever and shutter stuck how do I fix it
Is there film in the camera? If so it may be at the end of the roll and thus when advancing the film it jammed. Rewind the film then see if the lever and shutter operate. If not then a CLA is needed.
Oct 28, 2013 | Pentax K1000 35mm SLR Camera
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
The flip up switch to rewind the film has fallen off, I have all the original pieces but cannot fit the bar in. How do I take off the rewind lever to fix it?
Perhaps the following site will help you visualize the fixing. I remind you that these film cameras sell for very little now days and can be purchased for a song. see: http://www.slideshare.net/lokerd/pentax-k1000-35mm-slr
Apr 14, 2011 | Pentax K1000 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Pentax k1000
darrenwithey
just pull up the rewind knob.
Mar 13, 2009 | Pentax K1000 35mm SLR Camera
Rewind shaft installation
bremerfamily,
to remove the shaft, lift the knob until the film door opens, place a small screwdriver between the prongs and turn the knob to the left. pull the shaft down and out. replace the shaft------ if the new shaft has a notch on the collar just rotate the shaft while pushing back in. if no collar, use a pin to push the spring away while inserting the shaft----- don't force it or you will bend the spring.
Dec 22, 2008 | Pentax K1000 35mm SLR Camera
Film developing clear
Hello
This problem could have a number of causes,
To check to see if it is a camera fault of developing fault you could try using a cheap colour film in the camera and getting it developed at a normal photo processor.
This will determine in which half of the process the fault lies.
If the pictures from the colour film are the same then it must be a camera usage problem or fault.
If the pictures are ok from the colour film then it will be a problem in either the film being used, developing problem (poor mix of chemicals etc).
This will just speed up the diagnosis a bit.
Oct 02, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
175 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
