Question about Brother MFC-5440 Printer
Jammed paper tray for a Brother HL-5140
The paper tray was crooked while I was trying to insert it after filling it with paper. Now it is stuck and won't open or close
    Sergeant:
    Champion:
  • 357 Answers
Try removing the paper as it may be easier to grab and move while empty.
Good Luck.
Posted on Mar 16, 2009
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Paper tray is broken on laser printer Brother HL-5140
I believe you have to call you manufacturer and ask if you can purchase the tray separately. They might also give you a company that manufacture's parts of their printer.
Unfortunately I don't have any number about brother but you can visit their website and you might find their number.Their website is www.brother.com
Feb 27, 2009 | Brother Office Equipment & Supplies
HL-5140 paper jam
Perhaps look along the paper path for the little bit of paper that maybe stuck along the path somewhere. I had this problem and it was just a little piece of the corner of a page wedged in the back of the toner tray.
Dec 30, 2008 | Brother HL 5140 Laser Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Brother MFC-5440 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
