Question about Sony Playstation 3 (PS3) Console
Save your game data to a sd card and do a quick reformat of system this worked for me
    President:
  • 2,653 Answers
Check out my common PS3 problem and repair guide for tips and suggestions for any future problems.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 24, 2009
My 2gb san disk memory card suddenly stop working when i have downloading songs from internet
i think it has got virus.just format it.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive - Next -Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
Tip
Using Wii Powersaves
To use a Wii power-save, insert the SD card into the slot in the front compartment of the Wii. Next go to Wii options, data management, save data, Wii, and than SD card. Lastly, click on the game you would like to use power-saves for. Copy the save data on the SD card and start playing!
on Jan 12, 2009 | Datel PowerSaves with 512MB SD PowerSave...
My daughters nintendo ds keeps coming up with sd.tf card error.have read about formatting the card but will i loose all the data and pre loaded games?have also read about downloading a kernal which i have...
If you reformat the SD card you will not lose any of the software that is on the system. None of that data is stored into the SD card. The only thing that you can save to the SD card are pictures and you can back up you downloaded games onto it. Any software you have downloaded or came on the system will be completely unaffected if you reformat the SD card. Thanks for using FixYa!
Feb 04, 2011 | Nintendo DS Lite
My daughters nintendo ds keeps coming up with sd.tf card error.have read about formatting the card but will i loose all the data and pre loaded games? I have also read about downloading a kernal which i...
Hi anna21,
Formatting the card may fix the problem however you will loose all the data on the card. I have a solution here that can help you but you need a SD Card Reader on your computer to back up the files.
1. Put the SD Card in your Card Reader.
2. Connect it to your PC.
3. If the window pop-up like asking to open with what program select Open as File.
4. If the window does not pop-up, Go to My Computer/Computer. There should be the SD Card Memory.
5. Backup all the save file in your SD Card in other word copy the whole SD card. Save it in your computer. Make sure you remember where you put it.
6. Reformat the SD Card by Right Click and click Fromat
7. Tick Quick Format
8. After it finish formatting, Try open the SD Card. It should be empty.
9. Put back all the copied file back into SD Memory Card.
10. Plug it on your DS. Check the files. Play and Enjoy
Rate me if this helps so I can help others. Thanks for using Fixya.
Feb 04, 2011 | Computers & Internet
Son accidentally cleared unlocked tracks and character on his mario kart license. is there a was to retrieve them w/o having to go through unlocking them again?
Im sorry but once its deleted its over .. but u can unlock all the progress by downloading a pre saved save game for example these save files: http://www.wiisave.com/?cid=197 ..... u put them on an SD card like this..(Root Sd)/private/wii/(the save)..
finally to transfer from Sd to wii :
On the home menu, go select "wii" and then "save data options." You'll see two tabs at the top: "Wii" and "SD card." You may have a third tab for a game cube memory card, but ignore that.
Select "SD card." You'll see all the wii data saved to the card as graphic images. Select any you wish, and it'll give you an option to either copy or erase the file. Select "copy," and it will copy that data onto the wii.
Apr 25, 2010 | Nintendo Mario Kart (Wii) for Wii
Not recognising the disc drive
Hi...
Go into the System menu and find "Quick Format"...This reformats a portion of the hard drive and usually allows games and disks to be read
You will lose saved game data...Save it to an SD card if you can
Apr 23, 2010 | Sony Playstation 3 (PS3) Console
Saved data in a different wii system
found the following on the web under this link Wifi Data
First, to backup your Wii Fit save data, insert an SD Card and copy the Wii Fit game file to the card. You also need to Transfer all of your personal MIis to a Wii Remote. If you don’t, the characters will turn into guests on your friend’s console.
On the Mom’s console, go to the Mii Plaza first, and Transfer all of your Miis to their Wii (from your Wiimote).
Then, insert a blank SD Card. Copy their Wii Fit save data to it (if it exists). Then, erase their data from their Wii (make sure it’s backed up on their SD Card first!).
Remove their SD Card and insert yours. Copy your Wii Fit data to their Wii. Then go ahead and start and play Wii Fit with your save data.
You can simply reverse the process to transfer back.
Nov 18, 2009 | Nintendo Wii Console
Accidently Reformatted SD card and need important pictures back
you can recover photos from reformatted sd card with a professional photo recovery program, here's how you can do it
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech photo recovery (simply because i was using it and it worked), download the program from
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtml
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Jan 21, 2009 | SanDisk 2GB microSD Memory Card
Data transfer
Basically you need an SD card.
Located in the "Save Data" section of the "Data Management" area of the Wii Settings Save Data are the files created when you save a game's progress (such as high scores, items found, and where the game last saved), as well as data for certain Wii Channels
This data is stored in this section separately from the Wii Channel data, and can be kept, copied, or deleted independently of the Wii Channel it is used for.
Copy the Save Data to an SD Card, then delete it from the Wii
Most Save Data, including Virtual Console or WiiWare save files, can be copied to a compatible SD Card. This gives you the ability to delete that data, then copy it back over from the SD Card to your Wii should you wish to get it back at a later time. (Be sure to copy the data back over to the Wii when you wish to use it again; simply having the SD Card inserted with the data on it will not allow it to be used.)
Jul 09, 2008 | Nintendo Wii Console
Reformatting an SD memory cardf
You can format the card in your camera while not connected to your computer. In fact it's recommended to do so. Read your instruction book to find out how. It should be a selection available from your "menu" button when in image review mode. Select "low-level" or "full" format, not "quick" format (quick format is only good for erasing pictures).
Jan 12, 2008 | Cameras
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
