Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer heat not working
I have a Whirlpool dryer that is no longer heating. The model number is LER7646JQ0. What should I do?
  • jody_block Feb 27, 2009
    Hi there - the door switch seems to working just fine (what would i be looking for to determine if the door switch is not working properly?). I only found one fuse which is the thermal fuse (how can i tell if the thermal fuse is not working properly?). How can i tell if the heating element is not working properly?
    Regards,
    Jody
  • jody_block Mar 02, 2009
    Mike - thanks for your help. It was the thermal cuttoff.
    Genius:
  • 1,122 Answers
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Posted on Feb 26, 2009
  • 1 more comment
  • MIKE major Feb 28, 2009
    the door switch should have a clicking sound when you push it in and let it out,you need a meter to check the heater box fuse and the heater box element,or you can remove the heater box element and see if you see any broken wires on it,if you don't then you know it was to be the heater box fuse,let me know-mike
    SHOULD BE A FIXYA RATING-MIKE
  • MIKE major Mar 02, 2009
    GOOD JOB TROUBLE SHOOTING-MIKE
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Hello, I have whirlpool dryer model # LER7646JQ0. My dryer works great with one exception, it has no heat. I checked the heating element and all of the coils are intact. I then replaced the thermostat and...
Hello avonladywend,
After reading your post I can't help but wonder, have you checked to insure the dryer has 240vac going to it. These dryer's will appear to work almost perfectly with 120vac, with one exception...you guessed it, No Heat !
If you know the location of your homes service panel go to it. Locate the 30amp breaker and turn it all the way "off" and then all the way "on" do not just identify it and assume it is ok because ot doesn't appear "tripped".
This happens all to often when I go to a customers home. The first words out of there mouths is "It's not the breaker I checked" and then I physically check "reset" the breaker ( after verifying the dryer is only receiving 120vac and not 240vac with my meter ) and what do you know, heat !
That could be the problem all it's own. The other thing to look for is a poor connection ( loose and burnt or badly oxidized...or both ) on either of the "hot" cord lines coming into the unit, either the red or black.
Let me know what you find out, but that's where I'd be looking before installing anymore part's.
good luck.
macmarkus :)
May 01, 2010 | Whirlpool Dryers
Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Oct 18, 2009 | Whirlpool LER4634J Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
WHIRLPOOL DRYER STPS SPINNING AFTER A FEW MIN OF USE.
I would check the belt and the motor. The temp gauge has to do with the heating of the system. You can locate both of those at the back of the unit
Feb 11, 2009 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool Dyer, model #LHE5800WD
You have a bad timer. when you replace the timer it will start heating again. Get me the model # and i can get the part number and price.
Nov 19, 2008 | Dryers
Ghost in my dryer????
Here are a few ideas of what might be wrong.. based on your description.. You've bypassed the thermal fuse and the dryer worked however once you removed the bypass, did it work after that? based on your symptom.. it appears that one of the auto-ressting 'overtemp snap switches' may be your problem and may be shutting your system down because it is tripping from excessive heat or it is prematurely tripping because it is defective. I've included a website link that shows assembly drawings and parts breakdown for you to examine but I suspect that you have a bad overtemp switch.. ( I assume that you've cleaned out all lint etc from the vent system both inside and outside the dryer) If you haven't... then you may not get adequate air flow and you truly are getting an overtemp condition.. Good luck.. Here is the link http://www.pcappliancerepair.com/model-display.php
Hope this helps !
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
473 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
