Question about Maytag NMPEB08F2A Air Conditioner
Maytag Air Conditioner NMPEB08F2A
Keeps shut off! Emptied water and cleaned filter... now what? The tempertures outside have been in the upper 90's and low 100's.... need air conditioner! I thought Maytag was a good product?
  • 1 more comment
  • guineajewel Feb 03, 2008
    Have the same problem. Open the unit as suggested by removing all the plastic, however, unable to open the motor. I thought to buy the following parts and replace the motor.
    Part: CRCA3000-590 Motor, water for Maytag NMPEB08F2A, AT
    http://www.appliancefactoryparts.com/sea...
    Please help if you are having the same problem and know how to fix.
  • Anonymous Jul 10, 2008
    yup it short cycles. Never again Maytag this should keep Maytag repairman busy for life!
  • c2bc7777 Jul 15, 2008
    Unit quit...drained water...ran again...quit running...cleaned all parts I could get to...ran again...quit running...all with in a couple weeks...must have been getting lucky...thanks for your help...Mike
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Posted on Aug 16, 2007
2 Suggested Answers
  • 10 Answers
SOURCE: Maytag Air Conditioner NMPEB08F2A
the blower is not coming on chech for solutions in manual
Posted on May 31, 2009
Maytag com manual
Like most modern consumer products manuals, the answer to getting one is dead simple. Open Google, type in "User Manual, Maytag portable air conditioner Model NMPEB08F2A": and just like magic Google gives you back the following data response:: "http://usermanualnmpeb08f2a.yolasite.com/"
Just click on it and a seven..jpg icons appear on your computer screen, one each for a color photo of the seven pages of your manual for the Maytag portable air conditioner Model NMPEB08F2A
Modern computer information technology has made getting your hands on information and documentation extremely fast and simple.
Sep 06, 2014 | NMB Technologies Computers & Internet
Power light is blinking and the system will not run
The blinking power light indicates that the water collection tank needs to be emptied. Be sure to turn the unit OFF & unplug it, before draining the tank. And while you're at it, now would be a good time to remove and clean the air intake filter. Once these 2 things are completed, the unit should run as designed.
Thanks for choosing FixYa.
Sep 06, 2011 | Maytag NMPEB08F2A Air Conditioner
@gmail.comshould i need to put more freon in this air conditioner?
The only time you have to add freon is if you have a leak in the refrigeration system. Check and make sure all your coils are clean and the filter is clean. If its a cleaning issue these things will seem like its low on freon but is not just needs some love.let me know ok
Jul 23, 2011 | Maytag NMPEB08F2A Air Conditioner
HOW DO I RESET WATER AND FILTER ALARM SO I CAN GET IT RUNNING AGAIN. CAN'T FIND THE MANUAL. Mike Wells
I've used mine for 6 years. Works great. You really need to attach a plastic tube drain line on the top (middle back) drain valve and leave OPEN, and vent it outside. Let it drain when it wants. Otherwise, you'll be emptying that drain pan every 2 days.
Jul 23, 2009 | Maytag NMPEB08F2A Air Conditioner
Unit shut down & info light is flashing
Look for a pan that collects water or a door switch, the pan (if full willshut down the Unit ) or you didn't replace the panel properly. The first thing to check would be the POWER , Breaker ?.
Jul 18, 2009 | Maytag M6P09S2ACOM Air Conditioner
I have a used Maytag portable a/c, model #SMPEB08F2A. It has a little hole at the bottom left in the back which may be a drain but I don't know how to drain the water out. How and where do you drain the...
the drain is generally the midway in the back below the coil, there may or may no be an internal hose connected from the blower housing or evaporator coil housing, they are drained by gravity and the unit pitched to the outside should accomplish that if the drainage path is not clogged
Jul 14, 2009 | Maytag NMPEB08F2A Air Conditioner
May 31, 2009 | Maytag NMPEB08F2A Air Conditioner
Unit freezing up and shutting off
Ordinarily air conditioners do this when they are too big,(BTU wise), for the area being cooled. They will shut off to prevent system damage. There has to be enough warm air drawing back to the unit to keep the coils from freezing up. A more rare scenario would be an overcharge from the factory and manifest itself immediately.
Thank you,
Dave E. (Illeagle)
Jun 15, 2008 | Maytag NMPEB08F2A Air Conditioner
Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Jul 15, 2007 | Maytag NMPEB08F2A Air Conditioner
Maytag NMPEB08F2A Air Conditioner Logo
529 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
