Question about Asrock GE PRO-M2 Motherboard
Satellite A200 Not Charging battery
Upgraded BIOS, Replaced Power Pack and Battery, but still not charging battery. The battery charge light illuminates orange for 10 seconds and then goes out. Looks like motherboard fault. Anybody had this fault? Anyone have a solution? Thanks Andy
  • ajp4 Feb 24, 2009
    Thanks RescueTech
    Unfortunatley ony 1 Year Warranty and it expired Aug 2008. Was hoping that somebody had same fault and replaced regulators etc and cured. If I had a schematic I would stand 1/2 a chance.
    President:
  • 2,653 Answers
You're gonna have to replace the motherboard.
Check to see if it's under warranty through your motherboard manufacturer's website.
Most of them are covered for 3 years.
Best of luck!
Posted on Feb 24, 2009
  • RescueTechLA
    RescueTechLA Feb 24, 2009
    I didn't realize it was a laptop until after I posted that comment. It's usually very difficult to fix this problem. Have you already visually inspected the board for defects?
Is there any way to get past the EC power restriction foir BIOS FLASH...My L675D-S7049 Toahiba Laptop had a DEAD (Totally) battery due to a friend...AC shows input but NO CHARGING with new battery (OEM)...
The bios will and does not affect battery charging. Battery charging is carried out before the system and is a switch mode charger on board before the processing. If it required the processor to work and a bios, it would not charge when switched off!
I would suspect the OEM battery for the flashing light but the laptop should switch on with just mains power.
Has it been overheated?
May 29, 2012 | Toshiba Satellite Black 173 L675DS7049...
Toshiba M100 upgraded to Windows 7, i have just renewed the battery but i have a problem with th laptop not charging, info says it is plugged in but not charging, power adaptor is ok. the power charge...
When you say you renewed the battery, does that mean you replaced the battery with a new one? If your system is not charging up, try a different wall outlet. If that does not work, try a new power cord and lastly, a new battery.
After you have ruled out these three pieces of hardware, and you still have the problem, you would want to contact Toshiba for repairs as you are left with a malfunction on the laptop itself. Alternatively, you can contact a local computer repair shop.
Regards,
G33k
May 11, 2011 | Toshiba Satellite M100 Notebook
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
On the zt1135 pavilion the brand new battery won't charge. It is the correct battery replacement. OS: windows xp home edition. The orange light on laptop lights when battery is charging. Well, after...
well it can only be 3 things
bad battery
bad power pack
bad mobo.
the mobo as a charge chip, the power pack is just 19vdc .
if the chip is bad or there are shorted modules on the MOBO
the charging will fail. (battery good.)
is the power pack new, and 19vdc and at least 65watts>?
Jul 16, 2017 | HP Pavilion zt1135 Notebook
Battery won't charge
replace the power adapter, and if it still give the problem, change the batter.. if must be faulty that is why it is not charging.
May 19, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Does the powerjack on the back of the laptop look like it is lose? This is very common in laptops and is usually the source of charging/dead laptop issues.
Feb 24, 2009 | Toshiba Satellite A200-0ET00X Notebook
Problem with my laptop battery
the cells of battery had dead, you need to replae the cells or battery.
Nov 24, 2008 | Toshiba Satellite A205-S4617 Notebook
P30 not Charging
Remove the battery and see if the power light still flashes or stays on steady. Your battery could be dead and may need to be replaced. How many charge cycles has it been through, and/or how old is it?
Feb 24, 2008 | Toshiba Satellite P30-S701TD Notebook
Asrock GE PRO-M2 Motherboard Logo
195 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
