Question about HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply
Comaq SR 1000 worked when shutdwn now wont power up at all
I have a comaq SR 1000 pc when I last shut it down and later tried to restart it it does nothing. the green light on the power supply will only flicker on & off. I unplugged it from the wall. I opened the computer's side cover & disconeced the main power wire harness plug that went to circuit board . I then plugged the cord in the wall and the green light stays on but if you reconnect it back to the board it flickers on and off again. Would you have an idea what is wrong?
  • 1 more comment
  • Tim Crosslin May 11, 2010
    I meant green light stays on what? The computer or the power supply?
    Green line stays on what the computer or the power supply?
  • Will Godwine May 13, 2014
    Please take a picture, if you can. This way we can all see and have a better idea. Some connection need not to be connected.
  • HP Master
  • 2,295 Answers
You failed to test ATX supplies correctly
per De ice above.
it takes a jumper to bench test any PSU.
and a voltmeter, (and dummy loads of really savvy)
if the PSU does not turn on and run all fans (you never said the fan words)
then the PSU is bad. it must run for at least 1 second
if the PSU sees hard PS fails it shuts it self off, by DESIGN.
IF PSU is dead what can it be. sure easy.
  1. bad PSU. (my guess is this is IT) given age.
  2. psu unplugged from MOBO.
  3. mobo switch wires to switch bad ,fell off. bad switch , hot wire the switch to prove that.
  4. mobo bad, yes, the MOBO is the logic that turns on all PSUs and can fail but is very rare this, due to that logic is very deep in the glue logic., and almost never fails. but the MOBO has onboard regulators that will send power off to the PSU if they fail, or say a ram card shorts (an other things there)
http://pcdied.com/power.html
RULE1, never ever HOT switch (connect) any PSU to any MOBO
or you will blow up chips. why not get a tech fix this PC and not damage it MORE.?
on a working system we pull the line cord
then push front case power sw, and let that discharge all caps in the system or you will BLOW UP EXPENSIVE PART.
for sure. and we use ESD straps, electrostatic discharge starps
on our wrist to ground. to protect MOS logic chips.
or let the parts sit, powered down for 1/2hr, the play.
do that each time you remove internal parts, or put them back
or you will wreck it.
the LED glow at 2v or more, and tell you little.
in case of NYC, it tell you only that Niagara dynamo 1 is not off line.
LOL
we use tools one such tool is the $20 DMM in VOLTS Mode.
there are 5 to 10 PSU lines that can fail, DC lines
the MOBO has 2 or 3 regulators that can fail. and tell the PSU
to shut of so the $100 + CPU is not blown to H3LL .
this is how all PC work (DT) slime or not.
Posted on Jun 04, 2017
    Diehard:
    Visited the website for 60 consecutive days.
  • HP Master
  • 699 Answers
SOURCE: power supply light has blinking green light
After researching on the web I replaced the power supply. Problem solved.
Posted on Feb 13, 2008
nilesh17
  • 3 Answers
SOURCE: Power light which is green
chaque pwr sw pin in ur cpu
Posted on Nov 21, 2008
lafalot
  • 152 Answers
SOURCE: nx6310 wont stay on
HP is notorious for this problem. The problem is that the power jack that is connected to the motherboard has come loose. This is an easy fix is you are comfortable taking apart your notebook and are able to solder the jack back to the motherboard. I have 2 HPs and my friend has 2 and we have done this with ours as well as others. This is the link to the HP website that has your manual for disassembly .http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1839143 When you get to the page, download the Maintenance and Service Guide. (It is all the way at the bottom!) You will need Adobe Acroabt to read it. PRINT the instructions. They will do you no good if they are on the laptop that you are trying to disassemble!
While it may seem daunting, it is really not hard to do. Just be careful to follow all of the disassembly and reassembly instructions and you will have no problems. I promise!
Please remember to rate my solution! Thanks
Posted on Feb 05, 2009
Ownij
  • 67 Answers
SOURCE: pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Posted on Mar 16, 2009
  • 125 Answers
SOURCE: Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
Posted on May 30, 2009
My Samsung CoolTech Model SR-L709EVSS fridge and freezer works for a few days and then goes off by its self and then works again. What could the problem be?
Only time these units completely shut down is when the defrost timer shuts down all power to the compressor and condenser/evaporator motors. Only the bulb works.
If that timer gets stuck somehow that would explain the complete shutdown and mysterious restart later .
Jul 31, 2015 | Samsung Refrigerators
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
http://superuser.com/questions/14163/when-windows-xp-wont-restart-how-to-diagnose-how-to-shutdown-without-power-c
May 23, 2014 | Computers & Internet
My Eee pc 1000 notebook is booting in safe mode.
Yo! What you will do is give it emergency shut-down. do that by holding the power key for up to 5seconds for it to go off, then restart. after restart, you will see an option of BOOT NORMALLY, click on that and your system will boot normally.
Jul 24, 2011 | ASUS Eee PC 1000 Notebook
Have 2 units both just flash "loading" and will
This happened last night on my new-to-me JVC SR-MV55. Even powering it off for five minutes didn't help. It apparently crashed during dubbing (couldn't create more than 9 chapter codes?). Manual suggested holding down Stop and Power after powering it down. But no matter how long I held Power it wouldn't stop flashing. But I tried Stop/Powwer for a bit, nothing seemed to happen, then maybe 15 seconds later it restarted "WAKE UP'".
Mar 25, 2011 | JVC SR-MV55 DVD Recorder / VCR Combo
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Have a dell dimesni0n 2400. After shutting down on 20th March at 1000 attempted to restart later that day. Nothing appears on screen and light to left of start button blinks. Have checked leads and...
 i think you have to try to disconnet the power cord and after a little
time try to power up after connetting the cable, if the trouble remain
you have to see if the fun of power supply is running or not if it is running the main board i loading program , if not you have the power
supply with problem change it - delfo
Mar 21, 2008 | Computers & Internet
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
