Question about Linksys : WRT54GS Wireless-G Router W/ SpeedBooster (NELIWP17)
WRT54GS router stopped working
Power light lit, WLAN light-is lit, but blinks. DMZ light-not lit. Internet light-is lit but blinks. Ethernet 1-4 lights- not lit. Nothing has been touched and it has been working fine for over a year, all of a sudden my network is not available. I am able to connect on neighboring networks with 2 laptops with no problem, my network does not show as "available". I am not computer savvy, anyone have any easy recommendations? There are frequent power failures where I live and this seems to have stopped working after a power failure several weeks ago. Thanks.
Try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Posted on Jun 05, 2009
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Power, DMZ, WLAN leds OFF. Ethernet, Internet are solid ON.
With the signs that you have describe about your router, this is a clear signs that the router is already bad the hardware itself and better have it replace if still under warranty if not you need to go get a new one sorry about that router is dead already.
May 02, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
No power light, all other ports lit.
Well you know when you reset you router you have to reconfigure it so it works that could be it please email at joegoetz16@gmail.com if you need help
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G broadband router
Hi
No problem if dmz is off ( only if you put one of your computer outside router firewall it will turn on though tghis is not recomended )
Wlan will be on only if you are connecting wirelessly .
Yes if power is not on spells trouble .
Go to your router support site update latest firmware it will end the problem .
Feb 16, 2009 | Linksys Wireless-G Broadband Router
Some light on; some not
disconnect power supply from the router, wait for 30 seconds , and reconnet it back then check you get the power light.. if not try in a different power outlet..check the physical connection, the modem should be connected to internet slot in the router ,so that you would find the internet light lit up.., if still you do ont see the power light or the wlan light, reset your router, if you look at the back of your router, you would find a reset button, press and hold the reset button , with a pen on paper clip for 30 seconds with the power cable connected and disconnectc power and reconnect and then check..if still not the problem is with your router
Nov 16, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
487 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
